Decent adblocker for Internet Explorer 9
- Decent adblocker for Internet Explorer 9
07-02-2012 7:32 PM
After being a long time-user of Firefox, for reasons of compatability with friends and having just moved from XP to Win 7 64-bit, I'm trying Internet Explorer 9.
Can anyone recommend a decent adblocker?
Quite a few on the 'net, but Firefox's was so good and free!
Regards.....
Regards.....
5 REPLIES 5
Re: Decent adblocker for Internet Explorer 9
07-02-2012 9:47 PM
Tracking protection on IE9 works well for me, See here......http://windows.microsoft.com/en-GB/internet-explorer/products/ie-9/features/tracking-protection
If life gives you lemons, make lemonade.
08-02-2012 9:08 AM
I've always found modifying the hosts file to work a treat: http://winhelp2002.mvps.org/hosts.htm
08-02-2012 11:43 AM
Many thanks Steve and Matt for your speedy and detailed responses.
Most grateful.
Regards.....Noel
Most grateful.
Regards.....Noel
09-03-2012 10:13 PM
Or if you dont like editing the hosts file (i dont, unless theres something i *really* require blocking) - Try Peerblock
Benefit of this over hosts is you can see what is being blocked in real-time, and 'allow' it temporarily if required
(i use many lists from iblocklist to narrow down what can connect to a server i use)
Regards
Regards
10-03-2012 6:56 AM
Many thanks, Matt_2k34
Regards....
Regards....
