Damn Stupid
thisoldman
Damn Stupid
If i rip a track from a cd which i own , and rip it to mp3, when i play the track i get a message saying you need a licence to play this track.
But if i insert the cd and use sound recorder to record the track to mp3, it plays fine without a licence. That in my view is just damn stupid. anyone else found that?
Fixes: 4
Re: Damn Stupid
What program did you use to rip ?
Try a different ripper.
Re: Damn Stupid
or try a different media player.
thisoldman
Re: Damn Stupid
txs guys i was using win med player to rip and powerdvd for play back.
now i just record it using the excellent hauppauge sound recorder and powerdvd is happy
Re: Damn Stupid
I don't like Windows Media Player
Down load this free media player. It will play almost everything
http://www.videolan.org/vlc/
Fixes: 343
Re: Damn Stupid
Technically it is against the law to rip a CD you have to MP3, I don't believe they amended the law to reflect this..
Customer / Moderator / If it helped click the thumb / If it fixed it click 'This fixed my problem'
thisoldman
Re: Damn Stupid
txs for info adiewoo. is it also illegal to use hauppage sound recorder to record from a cd or radio etc etc? to mp3
Midnight_Caller
Re: Damn Stupid
Technically yes
VileReynard
All Star
Fixes: 11
Re: Damn Stupid
Quote from: thisoldman
Technically, you will get better sound quality if you rip from the digital CD.
Many programs will do this, provided that they aren't bought from M$.
