DVI over WiFi
DVI over WiFi
I've been asked to setup a display for an open day
Ideally I'd like to set up a standalone Monitor that is WiFI attached to a system unit in an adjactent room.
DAK if DVI over Wifi is possible?
Fixes: 20
Re: DVI over WiFi
There is Intel Wireless Display http://www.intel.com/go/widi/ - if you have a laptop with the latest Intel processor, graphics and wifi.
Fixes: 55
Re: DVI over WiFi
If its possible to run a cable at all then a 10m HDMI cable and DVI adaptors are going to be a lot cheaper http://www.aria.co.uk/Products/Cables/HDMI%2FMonitor+Cables/
