DVD Writer problem
- DVD Writer problem
DVD Writer problem
21-07-2008 8:36 PM
Windows XP could 'see' the drive & there are were no issues with it in device manager and I contacted LG for any driver updates and reinstalled the LG as the Master, becauses LG insisted on that. Now the LG works, but the slave [now the Lightscribe] still does not work. I changed the cable connection on the mother board, as there were 2 connectors and I was only using one. This prompted Win XP to reinstall and 'recognize' the drives again and all seems ok except the slave still will not play discs. I always get the same error message as before, that there is no disc in the drive when there really is!. I'm totally at a loss with this, as I've tried everything I can think of.
I made sure the jumpers were in the right place for master and slave and I've now tried putting the jumpers on the cable select pins and nothing changes the state of play! I've been into CMOS and both drives are listed correctly as maser and slave, whichever way I have the jumpers!
It's a real mystery.
Firmware is updated & drivers seem to be ok.
Any one got any ideas?
Re: DVD Writer problem
21-07-2008 9:07 PM
Is the ribbon cable an 80-core cable with Blue, Grey and Black connector blocks?
22-07-2008 12:59 AM
http://www.unixwiz.net/techtips/ide-cable-select.html
22-07-2008 1:31 AM
Quote from: HPsauce Should they perhaps be cable select (CS) not Master/Slave?
I did state but maybe not clearly enough that I've tried the jumpers as both cable select and Master/Slave. Either way it makes no difference.
I did state, but maybe not clearly enough, that I've tried the jumpers as both 'cable select' and Master/Slave. Either way it makes no difference, I still have the same problem.
The ribbon cable is as you describe but I did not count the cores to see if there were 80.
22-07-2008 1:48 AM
Regardless, I still have the same problem, whether the cables are CS or not and wherever the jumpers may be; it's probably not a cable problem.
22-07-2008 8:14 AM
Just a theory, not had this problem myself, but have heard about people with problems if the IDE cable is really long ... is your cable long or really short and just abou fits between the devices you wish to connect?
SW.
3Mb FTTC
22-07-2008 9:55 AM
31-07-2008 12:43 AM
I'll try it.
I have another cable on a spare machine.
Neither cables are overly long nor short, they seem to be a good length for the box.
09-08-2008 5:33 AM
09-08-2008 1:25 PM
Quote from: Midnight Did you get it working?
This is a weird problem. I have it partially working, but have not had the time yet to try 2 seperate cables for each DVD. At the moment I can ask 'Nero' to write to the 'Lightscribe' and it willl do so, but Windows does not see any discs I put in the 'Lightscribe' drive! So at the moment, the other DVD drive (Master) will play discs and the 'Lightscribe' (Slave) will not, but the 'Lightscribe' will write to blank discs!
At the moment, as I have this 'work around' where I can actually read/play discs in one drive and write in both, I can actually do all that one usually needs to do. I have not yet tested it, but see no reason why I can't copy from a disc in the Master to the Slave device. So I have the use of the 'Lightscribe' as a writer, but not as a player. The LG Master drive will read/play and write, so together I can manage most tasks I require; I just can't use the Lightscribe to play discs because Windows does not see them.
I think this must be a Windows problem, somewhow.
I'm delaying trying 2 EIDE cables, one for each DVD drive, as these cables occupy so much space and will clog airflow. I wish I had SATA DVD Drives! I already have a hot Athlon 64 +3700 processor so I hesitate doing anything to interupt airflow.
Phones ringing got to go...........
09-08-2008 9:03 PM
09-08-2008 10:43 PM
Quote from: Rikaitch Just a thought, but what about resetting the BIOS to defaults, forcing it to re-detect the drives. It might think it's still the old DVD-ROM, and isn't 100% compatible when it tries to talk to it. Just a thought.
I've recently updated the BIOS: would resting it to defaults undo that? I imagine not.
If it was thinking it was the old DVD Rom, which was able to play discs wouldn't this DVD writer also be able to play discs? I guess the system may be as confused as I often get dealing with Windows!
Thank you for your suggestion: I really appreciate the help, from all you guys.
I will try it.
