DVD Software
- Re: DVD Software
DVD Software
29-12-2014 3:11 PM
Hi all,
I have a laptop running windows 8.1 and have a dvd I would like to play. I used to just stick the dvd in and press play but I have found that doesn't work. I think that you have to buy the windows media centre now and the cyberlink programme that wants to automatically update is going to take hours. I would be grateful If anyone can offer any advice on the best way to proceed. I just want to download the most basic software to play a dvd.
3 REPLIES 3
Re: DVD Software
29-12-2014 3:36 PM
VLC media player works wonders and as its open source its free. http://www.videolan.org/vlc/
If life gives you lemons, make lemonade.
Re: DVD Software
29-12-2014 3:42 PM
Thanks very much M Steve, just downloaded it, took seconds and is just what I need, spot on.
Re: DVD Software
29-12-2014 4:12 PM
You're welcome southken enjoy the DVD
