DVD/RW for Dell OptiPlex G110
- Re: DVD/RW for Dell OptiPlex G110
09-05-2011 3:42 PM
09-05-2011 3:58 PM
09-05-2011 3:58 PM
LG is a good brand for such drives so I'd go for one of theirs, the "multi" range are fine and usually under £20.
Just make sure it's the same interface, presumably IDE not SATA.
09-05-2011 5:07 PM
After several years of research and experimentation I would thoroughly recommend the LG gh22lp20, assuming you need an IDE interfaced drive.
These are VERY reliable, fast, and usually come with both a black and an ivory coloured front bezel to match your PC case.
On eBay you can pick up immaculate and boxed examples for about £12 including p&p, or you should be able to buy them new for about £20 (+p&p)
09-05-2011 5:33 PM
Quote from: purleigh recommend the LG gh22lp20
I'm looking straight at an LG GH22NS40 (SATA) in my main W7 system.
12-05-2011 5:46 PM
Lg CDROM looks very solid so I am not surprised to see the same make recommended. Yes it will have to be IDE, machine does not know anything about SATA!!. I am just hoping that the case will be sufficiently identical to the old one, not a lot of margin for adjustment!!
12-05-2011 5:51 PM
Just a thought
12-05-2011 6:23 PM
Funnily enough I was looking at one of those just this week, but for hard disk purposes.
Even there I'm not sure what performance advantage their might be.
12-05-2011 6:28 PM
Quote from: HPsauce Why bother for an optical drive.......
Have to agree there but it does open up other possibilities.
12-05-2011 6:31 PM
Might even be the one that hangs behind the monitor....
12-05-2011 6:44 PM
12-05-2011 7:21 PM
Even my modern Windows 7 (x64) system gets confused re booting so I have an IDE DVD-ROM that I had to use to install the OS.
Everything else is SATA, including the main DVD-RW drive.
(The disks are mirrored RAID but the DVD-RW obviously isn't)
13-05-2011 12:04 PM
Agreed that it is a packed box but the existing CDROM by LG is quite substantial and big compared with some other CD Drives. I was hoping that the replacement would be of similar proprtions and go into the hole avaiable. I wonder if LG still tells us the size in their catalogues? Must try to see.
13-05-2011 12:40 PM
@Purleigh
Where do you recommend buying new?
13-05-2011 2:08 PM
http://www.scan.co.uk/shop/computer-hardware/all/blu-ray-dvd-drives/dual-layer-ide
Not had any problems when ordering from there at all, and they're definitely among the cheapest of the online stores.
