DSLstats/Routerstats issues with Ubuntu 12.04 (access violation)
- DSLstats/Routerstats issues with Ubuntu 12.04 (acc...
15-04-2014 3:14 PM
Things were fine with both programs but of late DSLstats has been throwing up a window that says "access violation press cancel to exit or OK to continue and risk data corruption" (or words to this effect). If I press OK DSLstats appears to hang and will not record any new data. It got to the point where the error was appearing within minutes or seconds of launching the program and it essentially makes the program unusable at times. I checked about online and there is a suggestion this is related to auto-saved snapshots, which I have disabled to no effect. Sometimes the program will run for hours without issues, other times it will crash before it records any meaningful data. Once it has crashed once it will usually crash constantly unless I restart my machine. I have updated the program several times (currently v4.50.1) with no change. It occasionally displays a "no data rerecorded" message also.
As a result of these issues I decided to switch back to Routerstats but when I try and run this program I get a message saying "cannot create file unix\home\ben\routerstats unix\home\ben\routerstats68k \RouterStats.chm. Path not found". If I click OK I get the configuration screen but if I click on any radio buttons I get a popup that says "Floating point division by zero", even when I click the close box. I have to exit the program with killall. Running it from the terminal gives me
ben@reticle:~/Downloads/routerstats68k$ wine RouterStats.exe
wine: cannot find L"unix\\home\\ben\\Downloads\\routerstats68k\\RouterStats.exe"
It's probably a stupid error on my part but does anyone have any ideas?
Re: DSLstats/Routerstats issues with Ubuntu 12.04 (access violation)
15-04-2014 4:14 PM
Quote "cannot create file unix\home\ben\routerstats unix\home\ben\routerstats68k \RouterStats.chm. Path not found"
That's 3 files!
Do you have a directory called unix?
If so, where is it?
15-04-2014 4:35 PM
As to your routerstats no real idea, but why are you running it from a shell rather than from the menu (assuming it was installed)
15-04-2014 5:04 PM
Quote from: vilefoxdemonofdoom
That's 3 files!
If so, where is it?
Hi vilefoxdemonofdoom
I realised that and assumed it was a WINE thing; I don't have any WINE experience. It's also asking for a file using \ (Windows) as opposed to / (pretty much everything else including Linux) but I assume this is WINE. There is no unix folder on my drive, at least that I can find. There is a .wine folder in /home but I couldn’t even find the folder there. Maybe there are issues with my WINE install.
Hi Hairy McBiker
DSLstats has never been run as root and all permissions for the program itself are correctly set. It seems like a permissions error but I cannot work out which directories are causing issues if this is the case. It could be a general program error though.
When I initially installed it I ran it as per these instructions. Once I checked it was running using the terminal as detailed in the instructions, I was running it from a shortcut. It just suddenly stopped working and I ran it in the terminal just to see what errors it spat out. I've had programs refuse to launch with no error message or a non-specific message and when I run them from terminal I've found the errors more verbose.
15-04-2014 6:31 PM
I've just ran it against my TG589 under wine happily.
15-04-2014 6:58 PM
15-04-2014 7:26 PM
15-04-2014 7:55 PM
Most of the bloat seems to end up in /home.
I have a small netbook which came with Windows 7 - which I was able to squeeze down to only 50GB.
This leaves 450GB for Linux so I use it in a dual boot configuration.
I don't update Windows - ever, but on the rare occasions when I'm forced to run it, at least it's running
in its own partition, which means that my Linux files are pretty safe.
15-04-2014 8:30 PM
Quote from: Hairy Easiest way to "fix" it, is extract Routerstats again to a DIFFERENT folder and run it from there.
No luck here but I've just tried running it with gksudo and it works like a peach but not really prepared to run it as root so I'll stick with DSLstats when it's playing nicely.
I've tried all suitable folders within /home. I've tried alternative versions too with the same result, including RouterStatsLite.exe. On the plus side DSLstats has been playing nicely since 2:25PM.
@vilefoxdemonofdoom
Not a massive fan of WINE myself; I only use it as a last resort. Like you I dual boot but the only programs I run in Windows are ARMA and Ableton Live 9, neither of which have a hope in hell of running in WINE. Most of the time when I have actually ended up using WINE I've found a decent Linux equivalent to whichever program I am trying to run within a short time.
16-04-2014 10:20 AM
But if you are happy with the other one stick with it.
16-04-2014 4:06 PM
ben@reticle:~$ cd .wine
ben@reticle:~/.wine$ ls -R
dosdevices drive_c system.reg userdef.reg user.reg
./dosdevices:
c: d:: e:: f:: g::
./drive_c:
Program Files Program Files (x86) users windows
./drive_c/Program Files:
Common Files Internet Explorer
./drive_c/Program Files/Common Files:
./drive_c/Program Files/Internet Explorer:
iexplore.exe
./drive_c/Program Files (x86):
Common Files Internet Explorer Propellerhead
./drive_c/Program Files (x86)/Common Files:
./drive_c/Program Files (x86)/Internet Explorer:
iexplore.exe
./drive_c/Program Files (x86)/Propellerhead:
ReBirth RB-338 2.0
./drive_c/Program Files (x86)/Propellerhead/ReBirth RB-338 2.0:
Default Songs Mods ReBirth.dll ReBirth manual.pdf
Demo Songs ReadMe.wri Rebirth.exe Unwise.exe
INSTALL.LOG ReBirth.cnt ReBirth.hlp
./drive_c/Program Files (x86)/Propellerhead/ReBirth RB-338 2.0/Default Songs:
Read Me.txt ReBirth 1.0 Default Song.rbs Silent Default Song.rbs
./drive_c/Program Files (x86)/Propellerhead/ReBirth RB-338 2.0/Demo Songs:
Alloy Cowboy Resurrection.rbs Metallicon City.rbs
A Taste of Haste.rbs Multiball Challenge.rbs
Calm.rbs Mutilated Species II.rbs
Clodhopper.rbs RSI.rbs
Fast Forward.rbs SuperNova.rbs
Fonda Workout.rbs TGV's KiloMix '98.rbs
Groove It Up a 2nd Time!.rbs Trakka Rekka.rbs
G-Spot.rbs Transfusion.rbs
./drive_c/Program Files (x86)/Propellerhead/ReBirth RB-338 2.0/Mods:
Metallicon.rbm MSM2.rbm Orbit2.rbm PBE2.rbm
./drive_c/users:
ben Public
./drive_c/users/ben:
Application Data Favorites My Music NetHood SendTo Templates
Cookies Local Settings My Pictures PrintHood Start Menu
Desktop My Documents My Videos Recent Temp
./drive_c/users/ben/Application Data:
wine_gecko
./drive_c/users/ben/Application Data/wine_gecko:
permissions.sqlite places.sqlite places.sqlite-shm places.sqlite-wal
./drive_c/users/ben/Cookies:
./drive_c/users/ben/Favorites:
./drive_c/users/ben/Local Settings:
Application Data History Temporary Internet Files
./drive_c/users/ben/Local Settings/Application Data:
./drive_c/users/ben/Local Settings/History:
./drive_c/users/ben/Local Settings/Temporary Internet Files:
./drive_c/users/ben/NetHood:
./drive_c/users/ben/PrintHood:
./drive_c/users/ben/Recent:
./drive_c/users/ben/SendTo:
./drive_c/users/ben/Start Menu:
Programs
./drive_c/users/ben/Start Menu/Programs:
Propellerhead StartUp
./drive_c/users/ben/Start Menu/Programs/Propellerhead:
ReBirth RB-338
./drive_c/users/ben/Start Menu/Programs/Propellerhead/ReBirth RB-338:
ReadMe.lnk ReBirth manual.lnk ReBirth RB-338 2.0.lnk
./drive_c/users/ben/Start Menu/Programs/StartUp:
./drive_c/users/ben/Temp:
./drive_c/users/ben/Templates:
./drive_c/users/Public:
Application Data Documents Music Start Menu Videos
Desktop Favorites Pictures Templates
./drive_c/users/Public/Application Data:
./drive_c/users/Public/Desktop:
./drive_c/users/Public/Documents:
./drive_c/users/Public/Favorites:
./drive_c/users/Public/Music:
./drive_c/users/Public/Pictures:
./drive_c/users/Public/Start Menu:
Programs
./drive_c/users/Public/Start Menu/Programs:
Administrative Tools StartUp
./drive_c/users/Public/Start Menu/Programs/Administrative Tools:
./drive_c/users/Public/Start Menu/Programs/StartUp:
./drive_c/users/Public/Templates:
./drive_c/users/Public/Videos:
./drive_c/windows:
command hh.exe Microsoft.NET rundll.exe syswow64 winhelp.exe
explorer.exe inf notepad.exe system temp winhlp32.exe
Fonts Installer regedit.exe system32 twain_32.dll win.ini
help logs ReWire.dll system.ini twain.dll winsxs
./drive_c/windows/command:
start.exe
./drive_c/windows/Fonts:
./drive_c/windows/help:
./drive_c/windows/inf:
./drive_c/windows/Installer:
2b08.msi ad1.msi
./drive_c/windows/logs:
./drive_c/windows/Microsoft.NET:
Framework
./drive_c/windows/Microsoft.NET/Framework:
v1.1.4322 v2.0.50727 v3.0 v4.0.30319
./drive_c/windows/Microsoft.NET/Framework/v1.1.4322:
aspnet_regiis.exe fusion.dll ngen.exe regsvcs.exe
./drive_c/windows/Microsoft.NET/Framework/v2.0.50727:
fusion.dll ngen.exe regasm.exe
./drive_c/windows/Microsoft.NET/Framework/v3.0:
windows communication foundation wpf
./drive_c/windows/Microsoft.NET/Framework/v3.0/windows communication foundation:
servicemodelreg.exe
./drive_c/windows/Microsoft.NET/Framework/v3.0/wpf:
presentationfontcache.exe
./drive_c/windows/Microsoft.NET/Framework/v4.0.30319:
fusion.dll ngen.exe
./drive_c/windows/system:
ddeml.dll mmsystem.dll Msvcrt.dll
./drive_c/windows/system32:
acledit.dll gpkcsp.dll qedit.dll
aclui.dll hal.dll qmgr.dll
activeds.dll hhctrl.ocx qmgrprxy.dll
actxprxy.dll hid.dll quartz.dll
advapi32.dll hlink.dll query.dll
advpack.dll hnetcfg.dll rasapi32.dll
amstream.dll hostname.exe rasdlg.dll
apphelp.dll httpapi.dll regapi.dll
appwiz.cpl iccvid.dll reg.exe
atl.dll icinfo.exe regsvr32.exe
attrib.exe icmp.dll resutils.dll
authz.dll ieframe.dll riched20.dll
avicap32.dll iexplore.exe riched32.dll
avifil32.dll imaadp32.acm rpcrt4.dll
avrt.dll imagehlp.dll rpcss.exe
bcrypt.dll imm32.dll rsabase.dll
browseui.dll inetcomm.dll rsaenh.dll
cabarc.exe inetcpl.cpl rstrtmgr.dll
cabinet.dll inetmib1.dll rtutils.dll
cacls.exe infosoft.dll rundll32.exe
capi2032.dll initpki.dll samlib.dll
cards.dll inkobj.dll sane.ds
cfgmgr32.dll inseng.dll scarddlg.dll
clock.exe ipconfig.exe sccbase.dll
clusapi.dll iphlpapi.dll sc.exe
cmd.exe itircl.dll schannel.dll
comcat.dll itss.dll scrrun.dll
comctl32.dll jscript.dll secedit.exe
comdlg32.dll kernel32.dll secur32.dll
compstui.dll ktmw32.dll security.dll
control.exe l_intl.nls sensapi.dll
credui.dll loadperf.dll serialui.dll
crtdll.dll localspl.dll services.exe
crypt32.dll localui.dll setupapi.dll
cryptdlg.dll lodctr.exe sfc.dll
cryptdll.dll lz32.dll sfc_os.dll
cryptnet.dll mapi32.dll shdoclc.dll
cryptui.dll mapistub.dll shdocvw.dll
cscript.exe mciavi32.dll shell32.dll
ctapi32.dll mcicda.dll shfolder.dll
ctl3d32.dll mciqtz32.dll shlwapi.dll
d3d10core.dll mciseq.dll slbcsp.dll
d3d10.dll mciwave.dll slc.dll
d3d8.dll midimap.dll snmpapi.dll
d3d9.dll mlang.dll softpub.dll
d3dcompiler_33.dll mmcndmgr.dll spool
d3dcompiler_34.dll mmdevapi.dll spoolss.dll
d3dcompiler_35.dll mprapi.dll spoolsv.exe
d3dcompiler_36.dll mpr.dll start.exe
d3dcompiler_37.dll msacm32.dll stdole2.tlb
d3dcompiler_38.dll msacm32.drv stdole32.tlb
d3dcompiler_39.dll msadp32.acm sti.dll
d3dcompiler_40.dll mscat32.dll svchost.exe
d3dcompiler_41.dll mscms.dll svrapi.dll
d3dcompiler_42.dll mscoree.dll sxs.dll
d3dcompiler_43.dll msctf.dll t2embed.dll
d3dim.dll msdaps.dll tapi32.dll
d3drm.dll msdmo.dll taskkill.exe
d3dx10_33.dll msftedit.dll taskmgr.exe
d3dx10_34.dll msg711.acm termsv.exe
d3dx10_35.dll msgsm32.acm traffic.dll
d3dx10_36.dll mshta.exe twain_32.dll
d3dx10_37.dll mshtml.dll unicows.dll
d3dx10_38.dll mshtml.tlb uninstaller.exe
d3dx10_39.dll msi.dll unlodctr.exe
d3dx10_40.dll msiexec.exe updspapi.dll
d3dx10_41.dll msimg32.dll url.dll
d3dx10_42.dll msimsg.dll urlmon.dll
d3dx10_43.dll msimtf.dll usbd.sys
d3dx9_24.dll msisip.dll user32.dll
d3dx9_25.dll msisys.ocx userenv.dll
d3dx9_26.dll msnet32.dll usp10.dll
d3dx9_27.dll mspatcha.dll uxtheme.dll
d3dx9_28.dll msrle32.dll vbscript.dll
d3dx9_29.dll mssign32.dll vcomp.dll
d3dx9_30.dll mssip32.dll vdmdbg.dll
d3dx9_31.dll mstask.dll version.dll
d3dx9_32.dll msvcirt.dll view.exe
d3dx9_33.dll msvcp100.dll wbem
d3dx9_34.dll msvcp60.dll wbemprox.dll
d3dx9_35.dll msvcp70.dll wer.dll
d3dx9_36.dll msvcp71.dll wiaservc.dll
d3dx9_37.dll msvcp80.dll windowscodecs.dll
d3dx9_38.dll msvcp90.dll winealsa.drv
d3dx9_39.dll msvcr100.dll wineboot.exe
d3dx9_40.dll msvcr70.dll winebrowser.exe
d3dx9_41.dll msvcr71.dll winecfg.exe
d3dx9_42.dll msvcr80.dll wineconsole.exe
d3dx9_43.dll msvcr90.dll wined3d.dll
d3dxof.dll msvcrt20.dll winedbg.exe
dbgeng.dll msvcrt40.dll winedevice.exe
dbghelp.dll msvcrtd.dll winefile.exe
dciman32.dll msvcrt.dll winegstreamer.dll
ddraw.dll msvfw32.dll winejoystick.drv
ddrawex.dll msvidc32.dll winemapi.dll
devenum.dll mswsock.dll winemenubuilder.exe
dhcpcsvc.dll msxml2.dll winemine.exe
dinput8.dll msxml3.dll winemp3.acm
dinput.dll msxml4.dll winemsibuilder.exe
dispex.dll msxml6.dll wineoss.drv
dmband.dll msxml.dll winepath.exe
dmcompos.dll mui wineps.drv
dmime.dll nddeapi.dll winex11.drv
dmloader.dll netapi32.dll wing32.dll
dmscript.dll net.exe winhlp32.exe
dmstyle.dll netsh.exe winhttp.dll
dmsynth.dll newdev.dll wininet.dll
dmusic32.dll normaliz.dll winmm.dll
dmusic.dll notepad.exe winnls32.dll
dnsapi.dll ntdll.dll winscard.dll
dplay.dll ntdsapi.dll winspool.drv
dplayx.dll ntoskrnl.exe winsta.dll
dpnaddr.dll ntprint.dll wintab32.dll
dpnet.dll objsel.dll wintrust.dll
dpnhpast.dll odbc32.dll winver.exe
dpnlobby.dll odbccp32.dll wlanapi.dll
dpwsockx.dll ole32.dll wldap32.dll
drivers oleacc.dll wmic.exe
drmclien.dll oleaut32.dll wmi.dll
dsound.dll olecli32.dll wmiutils.dll
dssenh.dll oledb32.dll wnaspi32.dll
dswave.dll oledlg.dll wordpad.exe
dwmapi.dll olepro32.dll write.exe
dxdiag.exe olesvr32.dll ws2_32.dll
dxdiagn.dll olethk32.dll wscript.exe
dxgi.dll oleview.exe wshom.ocx
eject.exe openal32.dll wsock32.dll
expand.exe opengl32.dll wtsapi32.dll
explorer.exe pdh.dll wuapi.dll
explorerframe.dll photometadatahandler.dll wuaueng.dll
extrac32.exe pidgen.dll xapofx1_1.dll
faultrep.dll ping.exe xcopy.exe
fltlib.dll plugplay.exe xinput1_1.dll
fwpuclnt.dll powrprof.dll xinput1_2.dll
gameux.dll printui.dll xinput1_3.dll
gdi32.dll progman.exe xinput9_1_0.dll
gdiplus.dll propsys.dll xmllite.dll
gecko psapi.dll xolehlp.dll
glu32.dll pstorec.dll xpsprint.dll
gphoto2.ds qcap.dll
./drive_c/windows/system32/drivers:
mountmgr.sys
./drive_c/windows/system32/gecko:
1.4 plugin
./drive_c/windows/system32/gecko/1.4:
wine_gecko
./drive_c/windows/system32/gecko/1.4/wine_gecko:
chrome.manifest mozalloc.dll omni.jar smime3.dll
components mozsqlite3.dll platform.ini softokn3.dll
dependentlibs.list nspr4.dll plc4.dll ssl3.dll
dictionaries nss3.dll plds4.dll VERSION
freebl3.dll nssckbi.dll plugin-container.exe xpcom.dll
hyphenation nssdbm3.dll precomplete xpcshell.exe
LICENSE nssutil3.dll redit.exe xul.dll
./drive_c/windows/system32/gecko/1.4/wine_gecko/components:
binary.manifest
./drive_c/windows/system32/gecko/1.4/wine_gecko/dictionaries:
en-US.aff en-US.dic
./drive_c/windows/system32/gecko/1.4/wine_gecko/hyphenation:
hyph_af.dic hyph_de-CH.dic hyph_gl.dic hyph_lt.dic hyph_sh.dic
hyph_bg.dic hyph_en_US.dic hyph_hr.dic hyph_mn.dic hyph_sl.dic
hyph_ca.dic hyph_eo.dic hyph_hsb.dic hyph_nb.dic hyph_sv.dic
hyph_cy.dic hyph_es.dic hyph_ia.dic hyph_nl.dic hyph_uk.dic
hyph_da.dic hyph_et.dic hyph_is.dic hyph_nn.dic
hyph_de-1901.dic hyph_fi.dic hyph_kmr.dic hyph_pt.dic
hyph_de-1996.dic hyph_fr.dic hyph_la.dic hyph_ru.dic
./drive_c/windows/system32/gecko/plugin:
npmshtml.dll
./drive_c/windows/system32/mui:
./drive_c/windows/system32/spool:
drivers printers
./drive_c/windows/system32/spool/drivers:
color
./drive_c/windows/system32/spool/drivers/color:
./drive_c/windows/system32/spool/printers:
./drive_c/windows/system32/wbem:
mofcomp.exe
./drive_c/windows/syswow64:
acledit.dll httpapi.dll regasm.exe
aclui.dll iccvid.dll regedit.exe
activeds.dll icinfo.exe reg.exe
actxprxy.dll icmp.dll regsvcs.exe
advapi32.dll ieframe.dll regsvr32.exe
advpack.dll iexplore.exe resutils.dll
amstream.dll ifsmgr.vxd riched20.dll
apphelp.dll imaadp32.acm riched32.dll
appwiz.cpl imagehlp.dll rpcrt4.dll
aspnet_regiis.exe imm32.dll rpcss.exe
atl.dll imm.dll rsabase.dll
attrib.exe inetcomm.dll rsaenh.dll
authz.dll inetcpl.cpl rstrtmgr.dll
avicap32.dll inetmib1.dll rtutils.dll
avifil32.dll infosoft.dll rundll32.exe
avifile.dll initpki.dll samlib.dll
avrt.dll inkobj.dll sane.ds
bcrypt.dll inseng.dll scarddlg.dll
browseui.dll ipconfig.exe sccbase.dll
cabarc.exe iphlpapi.dll sc.exe
cabinet.dll itircl.dll schannel.dll
cacls.exe itss.dll scrrun.dll
capi2032.dll jscript.dll secedit.exe
cards.dll kernel32.dll secur32.dll
cfgmgr32.dll keyboard.drv security.dll
clock.exe krnl386.exe sensapi.dll
clusapi.dll ktmw32.dll serialui.dll
cmd.exe l_intl.nls servicemodelreg.exe
comcat.dll loadperf.dll services.exe
comctl32.dll localspl.dll setupapi.dll
comdlg32.dll localui.dll setupx.dll
commdlg.dll lodctr.exe sfc.dll
comm.drv lz32.dll sfc_os.dll
compobj.dll lzexpand.dll shdoclc.dll
compstui.dll mapi32.dll shdocvw.dll
control.exe mapistub.dll shell32.dll
credui.dll mciavi32.dll shell.dll
crtdll.dll mcicda.dll shfolder.dll
crypt32.dll mciqtz32.dll shlwapi.dll
cryptdlg.dll mciseq.dll slbcsp.dll
cryptdll.dll mciwave.dll slc.dll
cryptnet.dll midimap.dll snmpapi.dll
cryptui.dll mlang.dll softpub.dll
cscript.exe mmcndmgr.dll sound.drv
ctapi32.dll mmdevapi.dll spoolss.dll
ctl3d32.dll mmdevldr.vxd spoolsv.exe
ctl3d.dll monodebg.vxd stdole2.tlb
ctl3dv2.dll mouse.drv stdole32.tlb
d3d10core.dll mprapi.dll sti.dll
d3d10.dll mpr.dll storage.dll
d3d8.dll msacm32.dll stress.dll
d3d9.dll msacm32.drv svchost.exe
d3dcompiler_33.dll msacm.dll svrapi.dll
d3dcompiler_34.dll msadp32.acm sxs.dll
d3dcompiler_35.dll mscat32.dll system.drv
d3dcompiler_36.dll mscms.dll t2embed.dll
d3dcompiler_37.dll mscoree.dll tapi32.dll
d3dcompiler_38.dll msctf.dll taskkill.exe
d3dcompiler_39.dll msdaps.dll taskmgr.exe
d3dcompiler_40.dll msdmo.dll termsv.exe
d3dcompiler_41.dll msftedit.dll toolhelp.dll
d3dcompiler_42.dll msg711.acm traffic.dll
d3dcompiler_43.dll msgsm32.acm typelib.dll
d3dim.dll mshta.exe unicows.dll
d3drm.dll mshtml.dll uninstaller.exe
d3dx10_33.dll mshtml.tlb unlodctr.exe
d3dx10_34.dll msi.dll updspapi.dll
d3dx10_35.dll msiexec.exe url.dll
d3dx10_36.dll msimg32.dll urlmon.dll
d3dx10_37.dll msimsg.dll usbd.sys
d3dx10_38.dll msimtf.dll user32.dll
d3dx10_39.dll msisip.dll userenv.dll
d3dx10_40.dll msisys.ocx user.exe
d3dx10_41.dll msnet32.dll usp10.dll
d3dx10_42.dll mspatcha.dll uxtheme.dll
d3dx10_43.dll msrle32.dll vbscript.dll
d3dx9_24.dll mssign32.dll vcomp.dll
d3dx9_25.dll mssip32.dll vdhcp.vxd
d3dx9_26.dll mstask.dll vdmdbg.dll
d3dx9_27.dll msvcirt.dll ver.dll
d3dx9_28.dll msvcp100.dll version.dll
d3dx9_29.dll msvcp60.dll view.exe
d3dx9_30.dll msvcp70.dll vmm.vxd
d3dx9_31.dll msvcp71.dll vnbt.vxd
d3dx9_32.dll msvcp80.dll vnetbios.vxd
d3dx9_33.dll msvcp90.dll vtdapi.vxd
d3dx9_34.dll msvcr100.dll vwin32.vxd
d3dx9_35.dll msvcr70.dll w32skrnl.dll
d3dx9_36.dll msvcr71.dll w32sys.dll
d3dx9_37.dll msvcr80.dll wbem
d3dx9_38.dll msvcr90.dll wbemprox.dll
d3dx9_39.dll msvcrt20.dll wer.dll
d3dx9_40.dll msvcrt40.dll wiaservc.dll
d3dx9_41.dll msvcrtd.dll win32s16.dll
d3dx9_42.dll msvcrt.dll win87em.dll
d3dx9_43.dll msvfw32.dll winaspi.dll
d3dxof.dll msvidc32.dll windebug.dll
dbgeng.dll msvideo.dll windowscodecs.dll
dbghelp.dll mswsock.dll winealsa.drv
dciman32.dll msxml2.dll wineboot.exe
ddhelp.exe msxml3.dll winebrowser.exe
ddraw.dll msxml4.dll winecfg.exe
ddrawex.dll msxml6.dll wineconsole.exe
devenum.dll msxml.dll wined3d.dll
dhcpcsvc.dll mui winedbg.exe
dinput8.dll nddeapi.dll winedevice.exe
dinput.dll netapi32.dll winefile.exe
dispdib.dll net.exe winegstreamer.dll
dispex.dll netsh.exe winejoystick.drv
display.drv newdev.dll winemapi.dll
dmband.dll ngen.exe winemenubuilder.exe
dmcompos.dll normaliz.dll winemine.exe
dmime.dll notepad.exe winemp3.acm
dmloader.dll ntdll.dll winemsibuilder.exe
dmscript.dll ntdsapi.dll wineoss.drv
dmstyle.dll ntoskrnl.exe winepath.exe
dmsynth.dll ntprint.dll wineps16.drv
dmusic32.dll objsel.dll wineps.drv
dmusic.dll odbc32.dll winevdm.exe
dnsapi.dll odbccp32.dll winex11.drv
dosx.exe ole2conv.dll wing32.dll
dplay.dll ole2disp.dll wing.dll
dplayx.dll ole2.dll winhlp32.exe
dpnaddr.dll ole2nls.dll winhttp.dll
dpnet.dll ole2prox.dll wininet.dll
dpnhpast.dll ole2thk.dll winmm.dll
dpnlobby.dll ole32.dll winnls32.dll
dpwsockx.dll oleacc.dll winnls.dll
drivers oleaut32.dll winoldap.mod
drmclien.dll olecli32.dll winscard.dll
dsound.dll olecli.dll winsock.dll
dsound.vxd oledb32.dll winspool.drv
dssenh.dll oledlg.dll winsta.dll
dswave.dll olepro32.dll wintab32.dll
dwmapi.dll olesvr32.dll wintab.dll
dxdiag.exe olesvr.dll wintrust.dll
dxdiagn.dll olethk32.dll winver.exe
dxgi.dll oleview.exe wlanapi.dll
eject.exe openal32.dll wldap32.dll
expand.exe opengl32.dll wmic.exe
explorer.exe pdh.dll wmi.dll
explorerframe.dll photometadatahandler.dll wmiutils.dll
extrac32.exe pidgen.dll wnaspi32.dll
faultrep.dll ping.exe wordpad.exe
fltlib.dll plugplay.exe wow32.dll
fusion.dll powrprof.dll write.exe
fwpuclnt.dll presentationfontcache.exe ws2_32.dll
gameux.dll printui.dll wscript.exe
gdi32.dll progman.exe wshom.ocx
gdi.exe propsys.dll wsock32.dll
gdiplus.dll psapi.dll wtsapi32.dll
gecko pstorec.dll wuapi.dll
glu32.dll qcap.dll wuaueng.dll
gphoto2.ds qedit.dll xapofx1_1.dll
gpkcsp.dll qmgr.dll xcopy.exe
hal.dll qmgrprxy.dll xinput1_1.dll
hhctrl.ocx quartz.dll xinput1_2.dll
hh.exe query.dll xinput1_3.dll
hid.dll rasapi16.dll xinput9_1_0.dll
hlink.dll rasapi32.dll xmllite.dll
hnetcfg.dll rasdlg.dll xolehlp.dll
hostname.exe regapi.dll xpsprint.dll
./drive_c/windows/syswow64/drivers:
./drive_c/windows/syswow64/gecko:
1.4 plugin
./drive_c/windows/syswow64/gecko/1.4:
wine_gecko
./drive_c/windows/syswow64/gecko/1.4/wine_gecko:
chrome.manifest mozjs.dll platform.ini ssl3.dll
components mozsqlite3.dll plc4.dll VERSION
dependentlibs.list nspr4.dll plds4.dll xpcom.dll
dictionaries nss3.dll plugin-container.exe xpcshell.exe
freebl3.dll nssckbi.dll precomplete xul.dll
hyphenation nssdbm3.dll redit.exe
LICENSE nssutil3.dll smime3.dll
mozalloc.dll omni.jar softokn3.dll
./drive_c/windows/syswow64/gecko/1.4/wine_gecko/components:
binary.manifest
./drive_c/windows/syswow64/gecko/1.4/wine_gecko/dictionaries:
en-US.aff en-US.dic
./drive_c/windows/syswow64/gecko/1.4/wine_gecko/hyphenation:
./drive_c/windows/syswow64/gecko/plugin:
npmshtml.dll
./drive_c/windows/syswow64/mui:
./drive_c/windows/syswow64/wbem:
mofcomp.exe
./drive_c/windows/temp:
./drive_c/windows/winsxs:
amd64_microsoft.msxml2_6bd6b9abf345378f_4.1.0.0_none_deadbeef
amd64_microsoft.vc80.crt_1fc8b3b9a1e18e3b_8.0.50727.4053_none_deadbeef
amd64_microsoft.vc90.crt_1fc8b3b9a1e18e3b_9.0.30729.4148_none_deadbeef
amd64_microsoft.windows.common-controls_6595b64144ccf1df_6.0.2600.2982_none_deadbeef
amd64_microsoft.windows.gdiplus_6595b64144ccf1df_1.0.6000.16386_none_deadbeef
amd64_microsoft-windows-msxml30_31bf3856ad364e35_6.0.6000.16386_none_deadbeef
amd64_microsoft-windows-msxml60_31bf3856ad364e35_6.0.6000.16386_none_deadbeef
manifests
x86_microsoft.msxml2_6bd6b9abf345378f_4.1.0.0_none_deadbeef
x86_microsoft.vc80.crt_1fc8b3b9a1e18e3b_8.0.50727.4053_none_deadbeef
x86_microsoft.vc90.crt_1fc8b3b9a1e18e3b_9.0.30729.4148_none_deadbeef
x86_microsoft.windows.common-controls_6595b64144ccf1df_6.0.2600.2982_none_deadbeef
x86_microsoft.windows.gdiplus_6595b64144ccf1df_1.0.6000.16386_none_deadbeef
x86_microsoft-windows-msxml30_31bf3856ad364e35_6.0.6000.16386_none_deadbeef
x86_microsoft-windows-msxml60_31bf3856ad364e35_6.0.6000.16386_none_deadbeef
./drive_c/windows/winsxs/amd64_microsoft.msxml2_6bd6b9abf345378f_4.1.0.0_none_deadbeef:
msxml4.dll
./drive_c/windows/winsxs/amd64_microsoft.vc80.crt_1fc8b3b9a1e18e3b_8.0.50727.4053_none_deadbeef:
msvcr80.dll
./drive_c/windows/winsxs/amd64_microsoft.vc90.crt_1fc8b3b9a1e18e3b_9.0.30729.4148_none_deadbeef:
msvcr90.dll
./drive_c/windows/winsxs/amd64_microsoft.windows.common-controls_6595b64144ccf1df_6.0.2600.2982_none_deadbeef:
comctl32.dll
./drive_c/windows/winsxs/amd64_microsoft.windows.gdiplus_6595b64144ccf1df_1.0.6000.16386_none_deadbeef:
gdiplus.dll
./drive_c/windows/winsxs/amd64_microsoft-windows-msxml30_31bf3856ad364e35_6.0.6000.16386_none_deadbeef:
msxml3.dll
./drive_c/windows/winsxs/amd64_microsoft-windows-msxml60_31bf3856ad364e35_6.0.6000.16386_none_deadbeef:
msxml6.dll
./drive_c/windows/winsxs/manifests:
amd64_microsoft.msxml2_6bd6b9abf345378f_4.1.0.0_none_deadbeef.manifest
amd64_microsoft.vc80.crt_1fc8b3b9a1e18e3b_8.0.50727.4053_none_deadbeef.manifest
amd64_microsoft.vc90.crt_1fc8b3b9a1e18e3b_9.0.30729.4148_none_deadbeef.manifest
amd64_microsoft.windows.common-controls_6595b64144ccf1df_6.0.2600.2982_none_deadbeef.manifest
amd64_microsoft.windows.gdiplus_6595b64144ccf1df_1.0.6000.16386_none_deadbeef.manifest
amd64_microsoft-windows-msxml30_31bf3856ad364e35_6.0.6000.16386_none_deadbeef.manifest
amd64_microsoft-windows-msxml60_31bf3856ad364e35_6.0.6000.16386_none_deadbeef.manifest
x86_microsoft.msxml2_6bd6b9abf345378f_4.1.0.0_none_deadbeef.manifest
x86_microsoft.vc80.crt_1fc8b3b9a1e18e3b_8.0.50727.4053_none_deadbeef.manifest
x86_microsoft.vc90.crt_1fc8b3b9a1e18e3b_9.0.30729.4148_none_deadbeef.manifest
x86_microsoft.windows.common-controls_6595b64144ccf1df_6.0.2600.2982_none_deadbeef.manifest
x86_microsoft.windows.gdiplus_6595b64144ccf1df_1.0.6000.16386_none_deadbeef.manifest
x86_microsoft-windows-msxml30_31bf3856ad364e35_6.0.6000.16386_none_deadbeef.manifest
x86_microsoft-windows-msxml60_31bf3856ad364e35_6.0.6000.16386_none_deadbeef.manifest
./drive_c/windows/winsxs/x86_microsoft.msxml2_6bd6b9abf345378f_4.1.0.0_none_deadbeef:
msxml4.dll
./drive_c/windows/winsxs/x86_microsoft.vc80.crt_1fc8b3b9a1e18e3b_8.0.50727.4053_none_deadbeef:
msvcr80.dll
./drive_c/windows/winsxs/x86_microsoft.vc90.crt_1fc8b3b9a1e18e3b_9.0.30729.4148_none_deadbeef:
msvcr90.dll
./drive_c/windows/winsxs/x86_microsoft.windows.common-controls_6595b64144ccf1df_6.0.2600.2982_none_deadbeef:
comctl32.dll
./drive_c/windows/winsxs/x86_microsoft.windows.gdiplus_6595b64144ccf1df_1.0.6000.16386_none_deadbeef:
gdiplus.dll
./drive_c/windows/winsxs/x86_microsoft-windows-msxml30_31bf3856ad364e35_6.0.6000.16386_none_deadbeef:
msxml3.dll
./drive_c/windows/winsxs/x86_microsoft-windows-msxml60_31bf3856ad364e35_6.0.6000.16386_none_deadbeef:
msxml6.dll
16-04-2014 5:59 PM
16-04-2014 6:13 PM
Cheers for the help anyway!
16-04-2014 6:18 PM
You could just rename it to .wine_old I personally have 2 wine folders, .wine & .wine_games to keep the important stuff from getting corrupted. Stuff like Newsbin & quickpar2
16-04-2014 9:22 PM
I assumed purge would, well, purge. It appears something within the .wine folder was borked. I've added ubuntu-wine/ppa to my sources as while reading trying to fix the issue I've read that v1.4 (as in the Ubuntu repositories) is pretty buggy, especially on an x64 system.
Thanks for all your help Hairy McBiker, problem solved.
