DOS Attack Reported In My Router
Steve
Seasoned Pro
In doing a search of the said I.P. addy  this is what i found out,
*************** - Geo Information
IP Address 116.4.69.***
Host 116.4.69.***
Location  CN, China
City Guangzhou, 30 -
Organization ChinaNet Guangdong Province Network
ISP ChinaNet Guangdong Province Network
AS Number AS4134 No.31,Jin-rong Street
Latitude 23°11'67" North
Longitude 113°25'00" East
Distance 8285.52 km (5148.38 miles)
Should i be concerned?
If life gives you lemons, make lemonade.
4 REPLIES 4
Re: DOS Attack Reported In My Router
Depends.... Are you using a netgear DG834 by any chance... if so, disable the DoS reporting in the router as it is not DoS.
What is reporting the DoS?
How often is it being reported?
If less that 1000 per second it is not DoS but normal 'internet noise' that everyone gets and the router correctly blocks and ignores.
Steve
Seasoned Pro
I'm using a Netgear DGN 1000 and just have this one in the report, It happened this afternoon. Oh and that it was a UDP Packet.
Then it is a false DoS report and it looks like your router is doing the same as the 834 range. Just disable that reporting in the router.
Steve
Seasoned Pro
Thanks for the advice Peter and also reassurance, I dont like it when my router reports them and it happens, But usually just once every few months, I have not really learned enough about DOS attack's, Perhaps i will learn a bit more about them so i know what im dealing with.
Cheer's,
              Steve
