DNS help in case PN let down
vendetta
To add there is a handy tool you can use and it is free if you are having DNS problems or just find PlusNet going down the pan which they are recently and seem to be a sinking ship!
I am afraid I cannot give you the link as Forum rules I am sure do not allow!
But the tool you are looking for Is [ Dns Jumper v2.0 ] please use common sense and make sure download safe and antivirus check before opening.
I do hope this helps some of you not just now but in the future .
I hope I did you Proud  -- lool -- Unlike PlusNet!  Wink Cheesy
adie:red removed all caps title as per link:rules
1 REPLY
Fixes: 143
Re: DNS HELP IN CASE PN LET DOWN
Locked in favour of http://community.plus.net/forum/index.php/topic,143619.0.html
Customer and Forum Moderator. Windows 10 Firefox 62.0.3 (64-bit)
