DLink DHP-302 issue?
Bought these homeplugs around september ish.  Initially they worked fine, transferring the signal from my router which is in the master socket, to the attic room, where wireless was a bit iffy.  Left them at standard settings.  Last week, changed router, due to a fault, and since then they have failed to work OK. What happens is, after the PC in the attic room is powered down, the homeplugs go into a powersave mode after 15mins.  Issue is, they refused to come out of powersave mode, and when I powered up the PC, just got a RED light on the powerline network, and the PC utility refused to see the one connected to the router, only detected the one connected directly to it. It also seemed the Master Homeplug, lost its master status. Only thing that would get them to work again, was to completely reset them to factory defaults, and set them up again.  Downloaded the latest firmware, and switched off powersave mode, and since yesterday, all appears OK, just no powersave mode. Googled this to no effect.  Anyone had this issue. DLinks website is a bit useless.....
