DECT Phone with SMS and Answer machine - Recommends please
shutter
Fixes: 67
As the title says,
looking for a DECT phone that can handle SMS text messaging  (send and receive ) and also with Answer machine.
Must have good volume on the talking side !  Some Panasonic types have reports of low volume, so I need to be careful in selection,
Thanks for any help and advice
EDIT EDIT.... must  be cheap, and possible on Ebay  not AMAZON... thanks
3 REPLIES 3
minkey
Re: DECT Phone with SMS and Answer machine - Recommends please
We've recently bought the Siemens Gigaset S850A which is good. Can connect bluetooth headset as well so should help with volume if it's not loud enough (I think it is though). Not the cheapest but has tons of features.
We bought from Ligo on Ebay (https://www.ebay.co.uk/usr/ligo_outlet) and they are generally cheaper than their own website and have refurb deals too.
shutter
Fixes: 67
Thanks, @minkey
Anyone else, got any recommedations, Please feel free to pass them on,
RobPN
Fixes: 15
I guess that recommendation wasn't cheap enough!
I recommend asking Mr Google which is what I suspect most people would do. Roll_eyes
