D drive
- Re: D drive
D drive
07-02-2012 6:28 AM
When I first purchased this HP laptop it was pre-installed with Win Vista, It was later upgraded to Win 7 from (upgrade) disc.
Presumably the pre-installed "recovery" D drive contains (since I didn't have recovery disc(s) with it) the original Vista.
Can the Vista be deleted and the D drive merged with the C drive without upsetting the rest of the PC?
1 REPLY 1
Re: D drive
07-02-2012 4:11 PM
I'd expect so, yes. I doubt there'll be anything on there that's used when the computer is up and running.
