D.P.E. shutting down adobe flash player.
- Re: D.P.E. shutting down adobe flash player.
13-09-2013 9:04 PM
I have a consistent problem with adobe flash player 11.8r800 being closed down by D.E.P. i have tried re-installing flash player, but still the problem exists.
I'm not very computer literate,and having read the read-me associated with it, I'm no further forward.
Can someone explain in simple terms what it means and what I can do about it please?
4 REPLIES 4
13-09-2013 9:51 PM
UPDATE..
I gave up trying to sort it out, think it may be a FF compatibility. Have installed Google chrome and all seems ok so far. Tho' not too sure I like chrome, seems to not be user friendly ( how do you get to the home screen after site hopping, without exiting and restarting?), but I will persevere.
13-09-2013 10:17 PM
Its suppose to protect reserved windows memory from viri. You can add exceptions or just set it for windows programs / services
right click my computer
then click properties
then advanced settings
then performance settings
then third tab for DEP
FTTP 500 regrade from Tues 28th November
14-09-2013 9:54 AM
Quote from: doris Tho' not too sure I like chrome, seems to not be user friendly ( how do you get to the home screen after site hopping, without exiting and restarting?).
Easy - try this: https://support.google.com/chrome/answer/95314?hl=en-GB
14-09-2013 7:52 PM
@Ffox, thanks. Sorted.
