Cumulative Security Update for ActiveX Killbits for Windows XP (KB2618451)
- Cumulative Security Update for ActiveX Killbits fo...
25-10-2012 11:06 AM
XP.....Anyone installed this update? seems to sit-and-do-nothing
1 REPLY 1
Re: Cumulative Security Update for ActiveX Killbits for Windows XP (KB2618451)
25-10-2012 12:39 PM
I have it installed on my XP machine here at work but it's been there since 15 December 2011 so I don't specifically recall whether it had any issues installing (I certainly don't remember any problems with it and it's marked with a green tick under status).
The most recent 'Update Rollup for ActiveX Killbits for Windows XP' showing on my system is KB2736233 installed 12 September 2012.
Call me 'w23'
