Cryptainer LE Free Encryption Software
- Cryptainer LE Free Encryption Software
26-07-2008 11:45 PM
Another of Samuria's free goodies I thought a few of you may be interested in this free ENCRYPTION SOFTWARE
Cryptainer LE, a free disk encryption software, creates multiple 25 MB of encrypted and password protected drives/containers.
The Cryptainer drive can be loaded and unloaded as per your need.
Just load your drive and drag and drop data into the Cryptainer drive and your data is encrypted.
Not only can you encrypt files and folders but you can also install programs in the Cryptainer drive which is accessible only through a password.
Cryptainer LE allows the creation of encrypted files that can be sent as email attachments. These files can be decrypted using the password and DecypherIT, a free utility from Cypherix™.
http://www.cypherix.com/downloads.htm
[Moderator's note by Daniel (Assos): Changed title from all caps into title case, please refrain from using all caps on the forums as it is considered rude and shouting, in addition to making things harder to read.]
2 REPLIES 2
Re: CRYPTAINER LE FREE ENCRYPTION SOFTWARE
27-07-2008 12:24 AM
thank-you samuria.. that looks very interesting. think will have a go ..
27-07-2008 12:31 AM
it is on my desktop as we speak... will delve into it later . thanks..
