Creating a user guide to bonding / load balancing internet connections.
- Creating a user guide to bonding / load balancing ...
17-10-2014 11:45 AM
I have dual Internet connections and I was considering creating a post or library article on how to bond these and load balance them, if any one was interested.
What do you think?
Mook
What do you think?
Mook
5 REPLIES 5
Re: Creating a user guide to bonding / load balancing internet connections.
17-10-2014 12:20 PM
I'd be interested in reading it, but I don't know how useful it would be. I would guess what you would do would be specific to your hardware, and a lot of it wouldn't be relevant to different hardware. It might however spark interest into someone who hasn't considered doing it before, and decides to go out and buy the same hardware.
If it was quite generic or covered a good range of different hardware, then it would make a good library article
Phil
Phil
17-10-2014 12:37 PM
Hi PJMarsh
Well if this helps the voting then it will be based solely on the hardware I am buying, so will be of limited use in that respect.
However, if it was done as a community library article then it would be easy for another user to add to it with their experience and hardware.
Mook
Mook
17-10-2014 2:58 PM
Would be a good idea if Plusnet explained their own load balancing foul-ups.
17-10-2014 3:39 PM
What load balancing foul ups ?
I was under the impression that it was only a theory
Quote from: Kelly <snip>
Our original theory on this being a load balancer configuration issue has turned out to be incorrect.
<snip>
17-10-2014 6:28 PM
There's the fundamental design flaw in that putting load balancers in front of the DNS servers (on the older non BNG gateways) results in an increased number of slow external DNS lookups being made (particularly noticeable in perverse test cases of repeatedly looking up the same hostname).
