Crash
- Crash
Crash
15-11-2017 5:01 AM
Switched on my laptop as usual this morning and was presented with a screen of coloured bands and a lot of loud bleeping.
A pop up message asked if I could see coloured bands, when answered yes, the computer went into a self test mode that is scheduled to take over two hours.
I have the option to pause, or escape, not that I can see how these can be selected as the mouse and touch pad is disabledbut have chosen to leave it testing.
Help!!
Re: Crash
15-11-2017 10:59 AM
Returned home from work having left the self-test running, I found that the test was complete, with a message if I wanted to reboot and, the mouse was working again.
Of course, I chose to reboot. This seemed to take rather longer than usual (not surprisingly I guess) but all seemed quite normal after that.
The screen during the test was a monochrome manufacturers (Dell), and apparently nothing to do with Windows 10.
Anyone any ideas?
