Couple of questions re fibre installation
Amalea
I'm currently a plus.net customer and I'm interested in switching to the fibre packages, but as I live in rented accommodation I've got a couple of questions I'd like to ask.
1. If we switch to fibre package (with the 18 month tie in) what happens if we move and our new address doesn't have the option of fibre? Can we downgrade to a lower package reducing the cost?
2. Once fibre is installed, if a new tenant moved in and didn't want to use fibre broadband, can the house still support a standard adsl connection?
Sorry if this is in the wrong section, really wasn't sure where to put it!
Thanks.
Re: Couple of questions re fibre installation
Quote from: Amalea
If you move and fibre isn't available at the new address, you'd be provided on the fastest speed we could get for you (and be charged appropriately for that).
Quote from: Amalea
Yes, but it'd need an engineer visit to switch the master socket back. If you're looking at getting fibre installed in rented accommodation we'd strongly recommend talking to the landlord about it before you do.
Amalea
Yeah, plan is to ask the landlord, trying to predict what he'd ask before contacting them to save time.
I'd assume that the engineer visit would cost a fee to switch it back (if needed)?
Cheers for the response.
Changing back would need an engineer visit but I don't think it'd cost any more than getting a line installed in the first place.
Amalea
Many thanks, time to contact the landlord!  Smiley
