Corsair ML Series Pro LED Case Fans
St3
Aspiring Champion
Fixes: 5
Ive ordered 4 of these to replace some stock fans, two of these will be fitted to my H100i V2 watercooler and the other two will be used for intake/outake.
Anyone using them ?
3 REPLIES 3
rongtw
Fixes: 12
Re: Corsair ML Series Pro LED Case Fans
na Steve i changed mine for Noctua Thumbs_Up
St3
Aspiring Champion
Fixes: 5
These are supposed to be as good as noctua from the reviews i saw.
St3
Aspiring Champion
Fixes: 5
I got them installed,  idle temps of 22oC with 500rpm ... when playing battlegrounds temps are 55-65 and 1100rpm.... im pretty happy with these well worth the cash to keep this hot chip cool.
