Core, blimey!
- Core, blimey!
Core, blimey!
05-08-2014 9:02 AM
Pausing isn't possible at this stage and there's, maybe, 5 or more hours left to run.
The two programs are DivX Plus Converter and Handbrake. What are the possible outcomes of right-clicking each process in Windows Task manager, selecting Set affinity... and unticking one or two of the Cores? Should this have been done before starting rendering or can it be done now with no major ill effects?
Forum Moderator and Customer
Re: Core, blimey!
05-08-2014 6:59 PM
Anyway, DivX? There are really people who are still using that codec?
Re: Core, blimey!
05-08-2014 9:02 PM
DivX Plus Convertor does convert to H.264/MPEG-4 depending on what setting you use and I have some files that don't render so well, if at all, with anything else. As these files will never ever get edited I am happy to go with what produces the lowest file size while keeping the quality.
I do have dedicated software but that would be overkill in this instance. Both Handbrake and DivX Plus Converter produce excellent results. DPC is currently reducing a 27GB 1920x1080 file to under 6GB.
Re: Core, blimey!
05-08-2014 9:42 PM
Re: Core, blimey!
06-08-2014 10:57 PM
Quote from: Mav DPC is currently reducing a 27GB 1920x1080 file to under 6GB.
That would be within the range of what I'd expect with some of my encodings that I know I can save space on, others definitely not. Either way if you've got a method that works for you, that's all that really matters. At least you are using the more efficient h264.
As to priority, I know what you mean about it being ok when you can let it run overnight. I try to set up as much as possible that way, but it doesn't always work out like that. With some projects I need to be editing both video and audio (usually the full six channels) at the same time as encoding something else (both video and other audio) because I've had so much to get through. When it's like this I'm working constantly over four HDDs so as to impede processes on each drive as little as possible (not clash them in terms of which disks are being used at which moments), and I set the x264 encodings to below normal most of the time, sometimes briefly to low when I need to extract anything from a file. This way I find I can be running several things at the same time, all with the view to setting up for the overnight video encodes so that come that completion all the audio is ready and whilst they mux I can be setting up the next batch to work on. Either way, the whole thing has driven me insane. I am glad I am at the end of a project that has taken me some months to complete. I hope it's not so long for you with whatever you're encoding, and it all works out smoothly.
Re: Core, blimey!
06-08-2014 11:16 PM
Happy with the result as it was almost impossible to see any difference between the two files. Have deleted the original now but I have quite a few more to do.
Sometimes I truly forget to lower the priority and, like you, can have several things going on at once from encoding to editing to copying. Even with temporary files on an SSD, 6 cores and several external hard drives each dedicated to one tasks things can slow to a crawl. Occasionally I'm happy to let that happen and work on my OU course using the laptop (all course work is save to the cloud anyway) meaning I can leave the PC to do its job.
Yesterday I noticed all 6 cores were working at 100% yet the core temps stayed below 60C. Trouble is I've been so busy with many different projects, sorting out my mother's finances and study that I still haven't fully edited my last trip to see SWMBO's family two years ago!
Re: Core, blimey!
08-08-2014 2:29 AM
27GB for a video?
Re: Core, blimey!
08-08-2014 7:13 AM
Re: Core, blimey!
08-08-2014 10:00 AM
SWMBO likes to keep a copy the unedited footage so I whittle it down as small as I can get without compromising quality.
Personally I like to whittle down 2/3 hours of footage to 20/30 minutes of watchable stuff
