Cordless mice
- Re: Cordless mice
Cordless mice
31-05-2008 7:21 AM
For my laptop I use a Logitech VX Nano Laser cordless mouse, which is brilliant and the best of it's type I've ever used, apart from anything else it has a tiny USB transmitter, that doesn't stand a chance of being snapped off or otherwise damaged during less than careful handling like the majority of other cordless laptop mice. However it is quite expensive (I've never really got on very well with touch pads)
I've noticed though that it can be used up to 10ft away from the computer and still move the pointer on the screen, not that I would want to but, I'm considering purchasing another for my wife, which brings me to the point of this post; does anybody know if, two of these mice used quite close together will they interact with each other, if (as often happens) both laptops are being used at the same time? Or is each mouse setup unique?
2 REPLIES 2
Re: Cordless mice
31-05-2008 7:54 AM
Normally the mouse syncs with the USB receiver when you click the button on each and only that receiver will work with that mouse. So you can use more than one side by side without problems as long as each one is synced separately.
Re: Cordless mice
31-05-2008 7:58 AM
As always Peter, an informative response, thank you.
