Converting MP3 Files
- Converting MP3 Files
03-10-2011 5:02 PM
I Have a load of MP3 files but my car CD will only play standard CDs.
Is there any simple program in Linux that I could use to convert these MP3 files into other formats that might play on a standard CD Player ?
We are born into history and history is born into us.
3 REPLIES 3
Re: Converting MP3 Files
03-10-2011 6:37 PM
Just use Brasero and choose Audio CD project then drop the mp3 in to it.
05-10-2011 4:28 PM
That worked no problem, couldn't believe it was that easy.
I Had a go with KB3 and just got messages it couldn't recognise the files so assumed I might need to download some additional files.
Brasero worked fine so thanks for your help !
05-10-2011 6:00 PM
You didn't say which distro/window manager you were using , but Brasero is fairly standard.
With k3b you may need some kde mp3 helpers if you are on Ubuntu etc, Mint already has them,
