Contact form abuse
- Contact form abuse
Contact form abuse
24-06-2008 4:53 PM
I run a website for a club I belong to, and today received from our contact form a number of slightly abusive messages aimed at one of our junior members. I will talk to the person concerned, because it might just be his mates having a laugh. If it turns out to be anything more serious I will consider taking it further.
The question for you lot is that the contact form (hosted by www.emailmeform.com) returns an IP address for the sender of the message. I ran a whois, expecting a reference to an ISP, and it comes up with the following. Clearly this is not the IP address of some local troublemaker. Can anyone explain why this address appears?
OrgName: Internet Assigned Numbers Authority
OrgID: IANA
Address: 4676 Admiralty Way, Suite 330
City: Marina del Rey
StateProv: CA
PostalCode: 90292-6695
Country: US
NetRange: 10.0.0.0 - 10.255.255.255
CIDR: 10.0.0.0/8
NetName: RESERVED-10
NetHandle: NET-10-0-0-0-1
Parent:
NetType: IANA Special Use
NameServer: BLACKHOLE-1.IANA.ORG
NameServer: BLACKHOLE-2.IANA.ORG
Comment: This block is reserved for special purposes.
Comment: Please see RFC 1918 for additional information:
Comment: http://www.arin.net/reference/rfc/rfc1918.txt
RegDate:
Updated: 2007-11-27
OrgAbuseHandle: IANA-IP-ARIN
OrgAbuseName: Internet Corporation for Assigned Names and Number
OrgAbusePhone: +1-310-301-5820
OrgAbuseEmail: abuse@iana.org
OrgTechHandle: IANA-IP-ARIN
OrgTechName: Internet Corporation for Assigned Names and Number
OrgTechPhone: +1-310-301-5820
OrgTechEmail: abuse@iana.org
# ARIN WHOIS database, last updated 2008-06-23 19:10
# Enter ? for additional hints on searching ARIN's WHOIS database.
OrgID: IANA
StateProv: CA
Country: US
CIDR: 10.0.0.0/8
Parent:
RegDate:
Updated: 2007-11-27
3 REPLIES 3
Re: Contact form abuse
24-06-2008 5:02 PM
You've done a lookup of an internal IP address i.e 10.0.0.x. You will get the same report if you do a lookup on 192.168.x which is the other range of IP addresses used by routers.
24-06-2008 5:43 PM
Below is an example of an email trace. The first IP address of 10.0.0.12 is off the PC that sent it to a local mail server at 81.149.196.232 which is a BT allocated static IP. So it will be here that for any abuse action will have to start.
25-06-2008 1:20 PM
Hmm, so the emailmeform site is only telling me the local IP address of the sender's PC. Not very helpful. It is likely this originated from a school network, so the local IP address might still be useful. The email trace won't help, as far as I can see, as it came from emailmeform, not from the message sender.
