Considering VDSL modem/router: Netgear vs Billion
- Re: Considering VDSL modem/router: Netgear vs Bill...
30-04-2015 1:10 PM
NETGEAR D6400-100UKS AC1600 Dual Band 300+1300 Mbps Wireless VDSL/ADSL
Billion BiPAC 8800AXL VDSL2(Fibre)/ADSL2+ Dual Band Wireless AC 1300
Thanks!
Edit: I just read that the Netgear doesn't support G.INP & Vectoring with the latest firmware (whatever that is! but it seems it's important for the UK)
Re: Considering VDSL modem/router: Netgear vs Billion
01-05-2015 6:59 PM
The website never gets updated & I've just been and checked it and the last update was 8 months ago! Which to be quite honest is pathetic and the main website still shows the 8800 NL as the latest model. Which sort of says what sort of company Billion is.
I would strongly advise you to look elsewhere.
01-05-2015 8:30 PM
Thanks.
I hardly ever had to contact any hardware support but for what I read, Netgear's is not good either
06-05-2015 12:17 AM
06-05-2015 9:48 AM
its amusing that the manual for the billion product he bought states WPS is disabled by default on the section about using it .......
adie:red removed offensive phrase.]
06-05-2015 2:35 PM
We went for the Billion in the end. It was very easy to set up, it worked straight away.
What I found a bit disappointing is that when setting the MAC filtering list, there was no way of identifying the devices. That is, in my old Netgear I could add the MAC address and a name. Here it's just the MAC address.
I still have to read a lot and go through more settings because there are SO MANY! I need time to learn
But even with the basic things I set up for now, I noticed a big increese in download speed. The Plusnet router was getting around 30Mbps, the Billion is usually above 40 (having reached 50Mbps!)
I'm happy for now.
06-05-2015 2:45 PM
under the mac filtering page I only have a port grouping where I have isolated the guest wifi from the main network.
other than that I have the url filter applied to specific fixed ip addresses and not to the remainder of users and of course I have time restrictions based on who's device it is, so the kids don't get internet access after they should be in bed or before they should be getting up.
there is a lot of info available though on all the features of the routers and billion tech support and their forums are a great source of info if you get stuck, my biggest hiccup was the way firewall rules are written (to me they should of been the other way round) and getting it wrong required a paperclip push to fix .....
06-05-2015 2:49 PM
06-05-2015 3:41 PM
07-05-2015 5:30 PM
Quote from: GR4CE Thanks nanotm! I'll definitely come back to this as soon as I can look into it and pick your brain
Don't pick to much as there isn't much there anyway.
