Connection to a robo hoover
Fixes: 382
Re: Connection to a robo hoover
On a phone, select 'desktop' from the dropdown menu (three dots), and then click the 'mountain' icon at the top of the reply window - or just use the laptop, whichever is easiest for you.
Anita1
I've changed the IP numbers & reset the router, tried to set up the hoover on the app again, but get exactly the same error message...-3004.1 failure to connect to device
Fixes: 579
In that case you're going to have to check with the supplier of the hoover
Anita1
Yes OK fine! Thank you for your help anyway
Fixes: 579
These sort of  devices are great when they work, but the. manufacturers provide no diagnostics to enable any fault finding when they don't work
