Connecting smart plug and light
Petermccann
I have been trying to connect to a smart plug and bulb and I tried everything and can't connect it was fine on other network before just big problem now if anyone can help I appreciate it
1 REPLY 1
Fixes: 581
Re: Connecting smart plug and light
Assuming you have a Hub 2 router, then temporarily disable the 5ghz wifi, connect the smart devices and then re-enable the 5ghz. Some devices are 2,4 ghz only and don't like the two wifi bands with the same name
