Connecting mobile with Wi-Fi
hamilton36
I bought a new mobile today and I would like to connect to Internet via my home router.  I have protected Wireless connection with a password, but it does not come up at all when doing the Search of available and hidden connections.  Can you help, please.
Thanks,
Alex
6 REPLIES 6
Fixes: 394
Re: Connecting mobile with Wi-Fi
Possible problems;-
You've disabled SSID broadcast on the router and the phone can't see it in a search
This shouldn't be a problem with a UK phone but...
Maybe the router wireless is on channel 12 or 13 , US wireless cards will only accept channels 1-11
Failing that what model mobile is it ?
hamilton36
Absolutely spot on, Mr. W. I have enabled SSID and all is now working.  I can download emails and access Internet free of charge when I am using Wi-Fi, but O2 are charging me when I send emails and they come as attachments from mediamessaging.02.co.uk and each contains a note that the message should not be replied to.  Is that usual, do you think?
Thanks,
Alex
tom:quote
Fixes: 394
What do you have configured for the email outgoing server ?
hamilton36
The SMTP server was set for relay.plus.net, but in the emal profiles the "kind" people at O2 listed all available sending options and put a <tick> against O2WAP PR...!!!! I have removed that and put a tick agaist Belkin 54G, which is my router.  I can now send and receive email free of charge, but I am not sure what will happen when I connect to a free Wi-Fi  away from home.  Do I have to go to email profiles and put a tick against the free Wi-Fi every time to stop the 'phone defaulting to O2?
Thanks,
Alex
Fixes: 394
I'm really not sure about that, it depends on the phone I'm afraid.
One thing you WILL need to do if you wish to send from other Wi-Fi networks is to use authentication to the Plusnet mail server ( relay.plus.net ).
I'm not sure what settings your phone has but you need to check an option something like:-
'Requires authentication' on the smtp server settings, you then will need a username/password. The username is your main PlusNet account name and the password is the main account password ( the ones you use to login to the PlusNet portal ( without the @plusdsl.net etc ) ).
You can try the settings whilst you are connected to your home Wi-Fi ( it will still work ) and then you can leave them like that.
hamilton36
Thank you. Much appreciated.
Alex
