Connecting PC to TV
- Connecting PC to TV
- « Previous
- 1
- 2
- Next »
Re: Connecting PC to TV
17-02-2008 7:16 PM
notheruser - I checked the nVidia site, and it said for my model that Sony required that drivers were downloaded from their own site. So I have installed the latest driver from Sony and have tweaked some of the settings in the nVidia Control Panel.
I’m not sure what exactly did the trick, but using the S-video to scart interface, I now get the full picture horizontally and am missing less then half an inch top and bottom. I suspect this is the best I am going to get.
The picture is acceptable, but as you say not up to the standard of a DVD. I have decided to put the exercise on hold until I change the TV, which will probably be HD-Ready. In that case, I assume that the HDMI interface would be the best option.
Many thanks for your help.
17-02-2008 8:52 PM
Great - glad you've had success
The new drivers are probably Sony's tweaked version of the latest nVidia ones anyhow.
I'm sure you're getting a great picture from DVD's on that set, so you'll be in no rush to change, but when you do, yes HDMI is the way to go.
20-02-2008 6:49 PM
Just found what looks like the ideal solution for you 12 v/mains portable 320Gb media player, USB2 to PC and Scart to TV with remote control for slides etc. Linky Maplins £99.99
20-02-2008 7:05 PM
pierre_pierre, well even if waldron is happy with the route he's taking, like the look of that for myself. Must get along to a Maplin branch for a looksee.
20-02-2008 7:08 PM
Offer price only up to 18th March
20-02-2008 7:17 PM
If you have a spare IDE hard drive available there is this cheaper solution Linky Maplins £39.99
21-02-2008 6:18 PM
Quote from: pierre_pierre Just found what looks like the ideal solution for you 12 v/mains portable 320Gb media player, USB2 to PC and Scart to TV with remote control for slides etc. Linky Maplins £99.99
Thanks for that. I'll have a detailed look at it.
- « Previous
- 1
- 2
- Next »
