Connecting LG TV to a powerline adaptor via wire
- Connecting LG TV to a powerline adaptor via wire
03-02-2019 7:07 PM
Hi, I've got a cable from the tv to the powerline adaptor and I can't configure the TV to connect.
It won't do it automatically and asks me to "set expert"
I get a screen saying Connect to network using auto setting IP address but it won't work so I'm setting the settings manually.
I've put in the IP address for my Plusnet Hub manager and the other Gateway and DNS settings but it won't work (Please see screenshot of what I've put in.
Please can somebody help me?
Pete
Re: Connecting LG TV to a powerline adaptor via wire
03-02-2019 8:02 PM
Use 192.168.1.1 as the IP address
Use 192.168.1.254 as the gateway
That should work
