Connect Samsung GT-S3650 to WiFi
bumbershoot
Is it possible to connect my gt-s3650 to my home wifi?.
4 REPLIES 4
Fixes: 393
Re: Connect Samsung GT-S3650 to WiFi
I'm not familiar with that phone but from looking at the specs here http://www.gsmarena.com/samsung_s3650_corby-2908.php it does not appear to have Wifi capabilities so I'm afraid the answer is No.
steveuk
There seem to be a few different models when looking around the net and it seems there is one called the Samsung GT S3650 Corby that has wifi.
Fixes: 393
I think you'll find it's the GT S3650W that has Wifi.
bumbershoot
"I think you'll find it's the GT S3650W that has Wifi".
This may be the problem. My local postmistress has an identical looking phone which works via wifi. Mine is lacking the W. Thanks
