Computer shutdown
- Computer shutdown
Computer shutdown
06-02-2012 4:05 PM
Is it the transformer & if so what power is still being used by the computer ?
My reason for asking is that my router, printer, scanner, etc are all plugged into an extension lead at the back of the computer desk which is almost impossible to get at, so if the router is left on (as recommended) then everything else is left on as well.
Re: Computer shutdown
06-02-2012 5:39 PM
06-02-2012 7:01 PM
These intelligent mains extension sockets will switch off your peripherals when your PC is shutdown, and reapply power when the PC is started again.
I have around 8 or 9 of these devices on my PCs for controlling peripherals, and on my TVs for powering down PS2, XBOX, Freeview receivers, DVD players, VCR, and DLNA video streamer.
There are various models to suit different applications as you can find here, and I usually pick mine up for about £4 to £6 new on eBay.
The simplest option would be to plug your existing extension cable into an IntelliPlug. You can often get these FREE from your electricity supplier, or about £3 (to cover postage) elsewhere (or on eBay).
06-02-2012 7:33 PM
The computer's power supply should have a proper off switch at the back, although that probably isn't much help.
06-02-2012 7:56 PM
Quote from: ejs And is the intellipanel / intelliplug intelligent enough to leave the router switched on?
Yes - the ones I've seen usually have a combination of sockets that turn off and others that are linked to the computer.
07-02-2012 3:17 PM
I Guess I will go for a couple of the plugs as my understanding of the panel is that the computer plugs into a specific socket on the panel so when you close down everything else attached to the panel closes as well so I am not sure how it would still allow the router to continue to function.
07-02-2012 11:01 PM
Quote from: gleneagles If a computer has been shut down (ie. you have logged off) but is still plugged in, what is still getting power ?
In my experience a marginal internal battery will discharge if the computer is unplugged but may not if the computer is still plugged in.
11-02-2012 2:46 PM
Quote from: purleigh Why don't you buy an IntelliPanel ?
Looking at some of the feedback on e-bay & Amazon about intelliplugs it seems that a number of people have found they fail within a short space of time. As they only cost a few pounds that may not matter but my concern is that any electrical item that has a high failure rate may also be a potential fire hazard although I do admit none of the negative feedback on this item has mentioned a fire risk.
11-02-2012 10:57 PM
The other reason they are cheap second hand on eBay, was that at one time the energy companies were giving them away for nothing to encourage customers to be more responsible about switching electrical items off - instead of leaving them on standby. Consequently rather than using the free IntelliPlugs, many people simply sold them and would rather have the cash.
I have probably bought about 15 various IntelliPlugs/IntelliPanels, none of them have ever given me any cause for concern.
12-02-2012 9:30 AM
I only use one but it powers down various peripherals such as my printer and speakers when I shut down my PC with no problems.
12-02-2012 1:09 PM
12-02-2012 2:06 PM
