Computer security
- Computer security
Computer security
08-12-2015 8:51 AM
My computer uses Windows 8.1 and has both Windows Essentials 2012 and McAfee LiveSafe. Do I really need to renew the latter please?.
6 REPLIES 6
Re: Computer security
08-12-2015 9:02 AM
I have always found AV products to be a waste of clock cycles, RAM and space. On my Windows machines I run the built in Windows AV and rely on common sense for the rest. If you are the only user then IMO I'd dump it and save your money and everything else that goes with the removal assuming you feel confident you can run without it. If the PC is shared then you would have to weigh up the risk factor the other users pose to the machine, if in any doubt renew it.
08-12-2015 9:11 AM
Hello Mook. You've confirmed my thoughts, and as a ''simple'' old age pensioner who is the only user, whose never entered twitter, facebook and other younger persons sites I'll get rid of McAfee when it runs out. Many thanks bewoh
08-12-2015 9:18 AM
Glad I could help. You may find this : https://service.mcafee.com/webcenter/portal/cp/home/articleview useful.
08-12-2015 11:48 AM
Make sure you have not unwittingly (or wittingly) signed-up to automatic renewal by credit card. Otherwise you will get charged for a McAfee renewal whether or not you use it.
08-12-2015 11:59 AM
ReedRichards..........many thanks...........I'll now do a check!!!..bewoh
08-12-2015 12:09 PM
@ReedRichards Well reminded.
