Computer Webcams Can Be Remotely Activated Without Showing Any Green Light
- Computer Webcams Can Be Remotely Activated Without...
19-12-2013 1:56 AM
The process of activating the camera without the light seems, in actual fact, is relatively simple.
All the person behind it needed to do was write a piece of software that essentially split the camera and light into two different entities, and from there, the camera could be seen through in a discreet manner.
Government agencies have been known to use these kinds of tactics for purpose of criminal investigation, as per the case of the aforementioned extortion, such techniques are floating around in public hands.
The only way to be sure that somebody isn’t spying on you through your MacBook’s FaceTime camera, would be to place a piece of tape, or other opaque material over it.
And it's not just Macbooks, this may apply to any computer with a webcam.
http://www.washingtonpost.com/blogs/the-switch/wp/2013/12/18/research-shows-how-macbook-webcams-can-...
Re: Computer Webcams Can Be Remotely Activated Without Showing Any Green Light
19-12-2013 3:58 AM
19-12-2013 12:19 PM
19-12-2013 12:47 PM
19-12-2013 3:02 PM
Now, the big worry is that the webcam on my netbook has no LED indication anyway, neither does the one on my phone or my tablet, anyone could be watching me at any time doing anything
Doesn't some anti-theft software rely on the remote activation of webcam function (without giving the fact away)?
19-12-2013 3:42 PM
19-12-2013 4:51 PM
https://jscholarship.library.jhu.edu/bitstream/handle/1774.2/36569/camera.pdf?sequence=1
the hack can be used with "Apple internal iSight webcams found in earlier-generation Apple products, including the iMac G5 and early Intel-based iMacs, MacBooks, and MacBook Pros until roughly 2008."
But could this happen to owners of newer Macs?
In the words of security researcher Charles Miller, it could happen, but it's less likely since it would take a "lot of work and resources."
Still, it's probably best to put a tiny square of electrical tape over your camera if you want to be absolutely sure.
19-12-2013 6:37 PM
19-12-2013 10:09 PM
Quote from: PlusComUK Still, it's probably best to put a tiny square of electrical tape over your camera if you want to be absolutely sure.
See above, I already suggested the use of some tape but the nay sayers said nay...
19-12-2013 10:16 PM
This is how I test a TV remote when it doesn't appear to be working, by aiming it at my phone camera I can see the IR-LED light up.
Can't test ultra-violet sensitivity as I don't have a UV light source but it wouldn't surprise me.
20-12-2013 1:02 AM
23-12-2013 5:34 PM
24-12-2013 1:49 AM
24-12-2013 6:30 PM
I always assume the camrea and sound is turned on, but why anyone would want to see my unshaven face at 7am defeats me.
