Computer Rebuild.
- Computer Rebuild.
Re: Computer Rebuild.
10-08-2014 11:47 PM
personally I keep mine on one of the other drives and set it to 60gig limit but I have 3 x 2tb wd black drives for storage and I remote located the entire users directory to one of the HDD's along with steam and origin (one drive for each) that way even if I have to reinstall windows I don't loose the users files or all the game downloads
11-08-2014 12:20 AM
Failing that, is it possible to map several volumes onto one physical drive like in Linux, using LVM?
11-08-2014 12:58 AM
Google "ssd alignment check" for further reading !
11-08-2014 5:56 AM
Quote from: nanotm you can always remote system restore to a HDD instead of keeping it on the SSD .......
I don't think that is possible (see e.g. http://answers.microsoft.com/en-us/windows/forum/windows_8-system/how-to-change-the-system-restore-l... ). If your OS is on the C: drive (for example) then your restore points are stored in the hidden 'C:\System Volume Information' folder which cannot be relocated.
11-08-2014 7:34 AM
As for a OS reinstall i dont find it the,, Worst Case ,, as it rejuvenates my system but what is a real pain is the Windows updates .
11-08-2014 8:20 AM
Quote from: rongtw Disable Disk Indexing
Turn off Scheduled Defragmentation
Disable Paging Files,, if you have more than 4gig ram
Deactivate Prefetch and Superfetch
i also have turned off windows search
also i have turned off system restore
& ensure you have got trim enabled
I'd agree with all that including, as mentioned by someone else, turning of indexing. I have actually turned off indexing for all drives and haven't noticed searches being particularly slower.
Quote from: ReedRichards
Quote from: rongtw also i have turned off system restore
You can make an argument for doing this even with a conventional hard drive but you can save yourself hours of work by using System Restore; a complete Windows re-install is the worst-case alternative.
I've never seen a complete Windows re-install as a worst-case alternative. In fact quite the opposite as it has given me the chance to set things up maybe a little differently than previously as my needs may have changed somewhat. I think I have only used System restore once and it didn't resolve the issue for me anyway. I have never missed it since turning it off when I initially installed W7.
Forum Moderator and Customer
11-08-2014 12:47 PM
If I try something and don't like the result I use System Restore to get me back to exactly where I was before. That prevents me from needing to 'refresh' Windows using a complete reinstall.
11-08-2014 12:54 PM
saying that i have used restore to fix other systems i have been asked to fix
11-08-2014 12:56 PM
Is this just a case of Windows thinking it is a HDD and not a SSD ?
11-08-2014 1:02 PM
11-08-2014 1:42 PM
Quote from: rongtw ... personally i prefer my system with it OFF as i do with other unnecessary MS services
The problem is that tweaks and personal preferences which apply equally well to any type of hard drive get conflated with things that you should do specifically for a SSD. Read any online 'advice' and you will find this.
I built a computer with a SSD for my other half. I
- Turned on AHCI in the BIOS before installing Windows (7)
- Checked that the trim function was reported as operational
- Checked/set no scheduled defragmentation
- I think I deactivated Prefetch and Superfetch (I'd have to verify that)
That's it, nothing else, otherwise a completely standard Windows installation with no tweaks. It's very fast, particularly noticeable when starting-up. And it has never yet suffered a BSOD.
11-08-2014 1:54 PM
As an aside I purchased Photoshop Elements 11 a while ago and having lost the installation files I downloaded a fresh copy, one install manager and one 1GB main program archive.
I ran the install manager and it told me the archive was missing....
No it's not....it's right beside you you stupid twat
Anyway I downloaded 7-Zip, extracted the archive and installed from there
11-08-2014 1:56 PM
Quote from: PitchBlack the Samsung magician recommends write cache buffer to be enabled, yet every time I enable it, I get a warning in windows event viewer saying "disk has it's write cache enabled. Data corruption may occur".
I expect that's nothing to do with having a HDD or SSD. Data corruption may occur because whatever is in the write cache buffer would be lost if there's a power failure, unless you have a UPS (or a laptop with a battery).
11-08-2014 3:30 PM
Quote from: rongtw @ReedRichards , yes i agree system restore is a great help in most cases , but personally i prefer my system with it OFF as i do with other unnecessary MS services
+1
11-08-2014 3:40 PM
I actually rely on the Acronis regular weekly backup
