Computer Rebuild
- Re: Motherboard Suggestions
Computer Rebuild
16-02-2015 4:39 PM
I don't do gaming on my PC but do some video editing.
I'm sticking a budget of £150 for the motherboard, fully understanding that the CPU will be substantially more.
I've looked at a Gigabyte board teamed up with an i5 chip.
Any personal experiences welcome.
dick:green Title changed to reflect current status.
16-02-2015 4:47 PM
But why are you going for the Z97X as opposed to an H97 unless you intend to overclock or intend to go for multiple GPU's
16-02-2015 4:49 PM
No, it was just an example and I won't be over-clocking.
I need full SSD support and the Z97X offers SATA Express support for 10 Gb/s data transfer.
A bit of background info:
I'm having daily blue screens and the error messages suggest a problem with the Marvell 6G interface feeding my SSD.
I have installed the latest drivers but they are dated 2010.
I'm looking to update the hardware in the hope that this and a fresh install of windows will fix the problem.
16-02-2015 7:27 PM
personally i prefer ASUS
16-02-2015 8:06 PM
Some good combos on today only....http://www.scan.co.uk/todayonly
16-02-2015 8:32 PM
16-02-2015 9:42 PM
16-02-2015 10:32 PM
http://www.guru3d.com/news-story/msi-offers-cashback-when-buying-motherboard-graphics-card-combo.htm...
18-02-2015 11:38 AM
sure its a duel core cpu but according to various reviews its cheap and does the job just as well as some of the higher priced stuff especially if you pair it with intel centric programs for video editing
18-02-2015 4:13 PM
18-02-2015 4:46 PM
18-02-2015 4:55 PM
The one thing which hasn't been mentioned is what the present system is
If it isn't too old the existing motherboard may well support a faster dual core processor
Although I don't do video editing my impression is that video editor use all four cores so a 4 core would be much better than a dual core
18-02-2015 9:20 PM
http://www.overclockers.co.uk/showproduct.php?prodid=MB-611-AS&tool=3
I know you said you aren't into gaming but my last ROG board lasted me over 5 years (and still going strong) before I built my new ROG system.
Good luck with your choice.
18-02-2015 10:12 PM
Motherboard
CPU
Memory
19-02-2015 1:18 AM
Quote Mobo: ASUSTeK model: M5A97
CPU: Quad core AMD FX-4350 cache: 8MB (4.2GHz)
8GB DUAL-DDR3 1600MHz RAM
Graphics: 1GB NVIDIA GEFORCE GT 730
This machine never gets used for mere game playing...
