Computer Crashing
- Computer Crashing
Computer Crashing
14-07-2010 8:28 AM
Computer keeps crashing if I do not delete the temporary files for a long period of time and if I do that I need to logging in websites like plusnet chat forums plus also I will not get updates unless I delete the temporary files, Are there any solutions out there to solve this problem.
Re: Computer Crashing
14-07-2010 9:07 AM
14-07-2010 4:55 PM
14-07-2010 5:40 PM
To do this -
Edit > Preferences
Select the "Privacy" tab
In the "History" section, change from "Remember history" to "Use custom settings for history"
Tick the box "Clear history when Firefox closes", Now select the "Settings..." button to the right
Then select any categories you wish to clear on exit, such as "Cache", etc. Click OK
Hit the "Close" button, and it is all set to clear the selected elements.
14-07-2010 5:46 PM
14-07-2010 6:44 PM
15-07-2010 7:30 AM
I am only using 2% of of hard disk.. I have took up nozzer's suggestion and see how I get on.
15-07-2010 8:47 AM
15-07-2010 12:41 PM
Quote from: idlewis Hi there
By "crashing" you mean....?? Freezing, blue screen, greyed out screen???
15-07-2010 2:10 PM
The computer sometimes freezes and it takes an hour plus or when it runs out of battery power.
15-07-2010 3:48 PM
Press these keys in this order and hold each one down as you do it .. Ctrl... Alt... Del.. You should then be presented with the Windows shut-down screen which gives you several oprtions, including the Start/restart symbol in the bottom right-hand corner. Press the Tab key until the up-arrow symbol is highlighted, then press Enter, and use the arrow keys to navigate to the Restart function, then press Enter and it should restart.
If that doesn't work, hold the start button in for at least four seconds and the whole shooting match will shut down instantly.
15-07-2010 4:17 PM
Do you what causes that and anything else I should do to stop it happening again.
15-07-2010 6:49 PM
