Compressed air
Mav
Fixes: 504
Compressed air
With the VIAO running a tad warm lately (CPU 60C average when idling) and the fan working harder and noisier than it used to I thought I'd look into attempting to blow as much dust away using a can of compressed air.
I found this in Amazon. Cheap but any good?
I would not try opening and serving myself and the local PC shop wants 50-55 squid Sad
Forum Moderator and Customer
12 REPLIES 12
RickK
Re: Compressed air
Hi Mav,
Generally any can of compressed air would do, from personal experience I even brought some at Asda once for £3 and it worked fine.
The downside of it being a laptop is that you will be spraying it into the air vents and most likely pushing dust further in.
When you use the VAIO I presume you are just sitting with it on your lap or a hard surface? Don't forget the hot weather also takes its toll on computers as it tries to suck air in to circulate through.
If you do use it on your lap, make sure you use like a wooden board or even get a lap rest because air needs to be accessible from the bottom of the laptop, most laptops will pull air in this way and push it out of the sides.
Good luck, and if you have any questions, please do let me know.
adamwalker
Fixes: 183
Re: Compressed air
It's OK, I'd risk it for about £4. I use the same stuff to clean dust off the motherboard for my desktop PC and the inside of my guitar amp (lots of valves and transistors that attract dust) it depends how much dust is in there and if any of the vents are clogged really, be careful you don't push the dirt further in like RickK says, I use an old makeup brush (property of an ex-girlfriend I'd like to state) which can be quite effective, I'd imagine any soft brush would work the same.. I'd also advise keeping your vacuum cleaner switched on and a hose nearby for any dust and detritus that might come flying out Smiley
 Adam Walker
Mav
Fixes: 504
Re: Compressed air
Thanks for the replies
Actually, it's never been used on  a lap. I gave it to SWMBO last year along with a stand so the air flow around it is ample. It's not particularly hot in our house so don't think it is related to the hot spell we're having.
Maybe I'll check out ASDA to see if they have any before buying from Amazon. Thanks.
Strat
Fixes: 565
Re: Compressed air
I use my vacuum cleaner's flexible extension with a narrow nozzle fitted.
That way the dust is sucked back out, a reverse of the way it went in.
Windows 10 Firefox 107.0 (64-bit)
Mav
Fixes: 504
Re: Compressed air
That may be a solution. Thanks, strat.
I'm used to putting the vacuum cleaner over the PC having taking the sides off.
It may save a few quid but, hey, rather my pocket than someone else's Cheesy
Strat
Fixes: 565
Re: Compressed air
As long as everything that should be in the case is still in there after you have finished.
I once sucked a SATA cable out of a PC and wondered why it wouldn't boot afterwards Embarrassed
Nibiru
Fixes: 12
Re: Compressed air
@strat - I bet you were better at sucking spaghetti when you were younger, and leaving nothing in the bowl  Wink
Plusnet FTTC 80/20 IPv4/30, Hurricane Electric 6in4 IPv6/48, Pulse8 landline & calls, SamKnows 600N
Vigor 130 modem, pfSense 2.6.0 router, DrayTek WAPs, Devolo dLAN 500, Gigaset N300A-IP VoIP DECT
ReedRichards
Seasoned Pro
Fixes: 25
Re: Compressed air
I had a decent laptop repair store in my area until it got taken over.  They kept a big cylinder of high pressure air which they once used for me to good effect and for only a small fee.
w23
Fixes: 4
Re: Compressed air
'Real' compressed air is usually a lot better then aerosol cans of 'propellant' but not everyone has access to it.  With the right fittings you could use the spare tyre off your car as a source.
Call me 'w23'
Mav
Fixes: 504
Re: Compressed air
Ran the vacuum cleaner over all the vents and now the CPU it's idling at a more comfortable 49/50C and only went up to 51C while playing HD video and running lots of other programs.
System temp hasn't gone over 53C since Smiley
Edit: I also just used the vacuum on my own laptop which was idling around 50/55C and is now a very cool 44C.
Thanks strat Smiley
rongtw
Fixes: 12
Re: Compressed air
Cool i am ok my neighbor has a compressor in his workshop , which i use once a month free of charge .PS  my tower has a handy carrying handle
Nibiru
Fixes: 12
Re: Compressed air
I have one of these powerful monsters -
for when I need a serious blow job  Kiss
