Comparitive ISP performance
- Comparitive ISP performance
21-11-2019 5:41 PM
I came across an interesting page in BT's financial statements regarding the performance (speed) of different ISP's:-
Re: Comparitive ISP performance
24-11-2019 7:42 PM
I see Plusnet is shown on the graph as 66Mb which funny enough is what is shown when I go into my broadband section. Coincidence? Maybe. I use to get 78Mb. It'll be interesting to see if my line improves when I change ISP.
28-12-2019 8:52 PM
Well, that is a bit of a shocker considering how long it's been since I last achieved a 78Mb sync - i.e. quite a few years..
Changed ISP and started off at a lowly 58.5Mb. Come 19th Dec and sync had gone up to 69860 and I really thought, same same as I used to get at PN. Today, I had another look to find the line is now syncing at 79848. Maybe I should have switched ISP much earlier.
28-12-2019 9:52 PM
@idonno did you install a better modem when you changed ISP, or is it the same one that you were using previously with Plusnet ?
I experimented with several different modems when I upgraded to FTTC, and was surprised at the wide variation in attainable sync speeds between devices. Currently I get the highest sync speeds with a DrayTek Vigor130.
Vigor 130 modem, pfSense 2.4.5-p1 router, 5 WAPs, Devolo dLAN 500, Gigaset N300A-IP VoIP DECT
28-12-2019 10:48 PM
I'm just using the same piece of kit and cables that I used with PN i.e. Vigor 130 and a TP-link C9 router. All that's been changed was the username and password to log on to the new ISP.
