Cloning laptop hd to larger capacity hd.
Pete11
Seasoned Pro
Fixes: 4
I am seriously considering swapping my laptop hard drive for one with a larger capacity and cloning OS and everything else across. Having done some reading up, it seems I have to leave the old drive in the laptop and link the new one via USB but am a bit stumped as how to link it up being as obviously it's an internal drive. So the question is..how is this done?
Secondly, Which programme would be better to use when I haven't done this before except once using DriveClone and that was back in early XP days. I have been told that DriveImage or Clonezilla are both good...but what do you think?
A float tip is pleasing in its appearance and even more pleasing in its disappearance.
Growing old is inevitable...But growing up is optional.
16 REPLIES 16
Fixes: 1,482
Re: Cloning laptop hd to larger capacity hd.
I'd go with CloneZilla Smiley
Pete11
Seasoned Pro
Fixes: 4
@dvorak
Thanks for your input on the software, but how do I attach the new hd to usb?. By the way, I checked in the BIOS and I don't have the option to boot from USB, it's either HD or Disc.  Undecided
jaread83
Fixes: 81
When I was an engineer we used a device to connect internal HDDs via usb. It basically converts your HDD to be a USB HDD without an enclosure.
https://www.amazon.co.uk/USB-SATA-Adapter-Cable-Drives-en-GB-SATA-USB-3-0-converter/dp/B01N2JIQR7/re...
Some computers have ESATA which just requires a cable that will plug in to a port directly to the HDD.
Fixes: 1,482
I use an adapter similar to the one @jaread83 shared Smiley
jaread83
Fixes: 81
price point of £5.99 is a lot cheaper than when I got my IDE to USB converter back in 2004!
Mustrum
Fixes: 76
I used a similar conversion kit fro SanDisk, it cost me a lot less than this one but not many people seem to sell them now:https://www.amazon.co.uk/SanDisk-SDSSDCK-AAA-G27-SSD-Conversion-Kit/dp/B008ZIO1CW
jaread83
Fixes: 81
As a side note, I used to use Norton Ghost at an enterprise level but it looks like the software has now been discontinued. I had a look at Clonezilla and this looks perfect for a single machine clone/backup/restore solution.
Pete11
Seasoned Pro
Fixes: 4
Cheers guys, just been looking at some enclosures on Amazon, and from £3.99 it looks like they got a sale. Also been looking at CloneZilla and a couple of other progs...still not sure which to go for yet though.
jaread83
Fixes: 81
If you get to the point where you have cloned the HDD and plugged it in to boot up and it doesn't work... you can always put the old HDD back in and try something else Smiley
Pete11
Seasoned Pro
Fixes: 4
@jaread83
That's a good point. DriveClone was very easy to use and it also managed the size of the partitions (if any) automatically. Will have another look at CloneZilla.
EDIT.
DriveClone  now has a free version AND now works in Win7. Happy days.  Cheesy
jaread83
Fixes: 81
Let us know how it goes!
wisty
Fixes: 8
If you get an enclosure, after cloning and swapping the hard drive in the laptop, stick the old one in the enclosure and use it as a backup device.
Pete11
Seasoned Pro
Fixes: 4
@wisty
I was thinking the same. It'll come in handy for storing a few bits and bobs. I do have an external but that's not far off full, having said that it's only a 250 gig.
ReedRichards
Seasoned Pro
Fixes: 25
Have you considered cloning your hard drive to one of a smaller capacity?  Replacing a conventional electro-mechanical hard drive with an SSD can do wonders for the performance.  But SSDs are a lot more expensive per unit of capacity than old-fashioned hard drives.
