Clock applet
Fixes: 9
Clock applet
Using Mint 11, every now and then I get the message the Clock applet failed to load ?
Is this something to do with the software on my machine ?
Not a problem but it's handy having the time on the  task bar.
VileReynard
All Star
Fixes: 11
Re: Clock applet
It could be failure to access a internet time server.
You should be able to set up several to try.
Steve
Seasoned Pro
Re: Clock applet
I think Its broken tbh as I get this problem too, Its why I have went back to the stable LTS Isadora, Everything just works on that release.
If life gives you lemons, make lemonade.
Fixes: 9
Re: Clock applet
Not an option for me as Mint 11 is the first Linux OS I have ever used  and am well impressed with a number of things about it. A missing clock in the task bar is a minor detail.
Added a fair bit to my knowledge looking at the responses to Shutters questions.
Steve
Seasoned Pro
Re: Clock applet
Sorry I should clarify the clock applet behaving strangely Is not the only reason I went back to the LTS.
Fixes: 21
Re: Clock applet
I have no issues with the clock, but occasionally it will fail to load the Show Desktop & active programs applets. A log off/on usually fixes it.
I also use Avant Window Manager as a dock so I have a clock on it  Wink
moodymark
Re: Clock applet
Ive seen some funny things happen on Ubuntu with the Gnome toolbars (versions 9.x through to 10.x) where the date / clock applet gets jumbled up with the logout and newtwork manager applets. Usually a logout and login will sort it. To reset your desktop to default, you can remove the .gnome2, .gconf, .gconfd directories. Not sure if Mint will use the same directories but its likely.
VileReynard
All Star
Fixes: 11
Re: Clock applet
newtwork
  Grin
Fixes: 174
Re: Clock applet
Something fishy there Undecided
Customer and Forum Moderator. Windows 10 Firefox 64.0 (64-bit)
