Cisco VPN
TheWarlock
Cisco VPN
May or may not be related. Trying to use works Cisco VPN to connect back to office (never used present companies VPN before and only been with plusnet ~10 days). Is there anything with the 582 router, or Plusnet service, that may block it? I'm getting a 413 authentication error. Just wanted to double check here first,
Cheers
1 REPLY 1
MauriceC
Resting Legend
Fixes: 17
Re: Cisco VPN
No problem that I'm aware of and I use Cisco VPN daily, but with an older Thompson router.  I get the occasional drop-out,  but that's more because of my poor line.
HTH
Maurice
