Chromecast
Prx1988
Chromecast
Has anyone managed to get a UK Chromecast working with PN?  The set up fails at the last stage.  It looks like the Chromecast gas joined the network (it says so on screen and the router shows it as a connected device) but no devices can actually connect to it.)
Google's help suggests AP isolation as being the cause, but I can't find any way to change that on my Technicolor TG582n FTTC Broadband router.
I've tried switching the firewall off and the network is on channel 1 so the channel 13 issue (which may have been fixed by Google anyway) isn't the issue.
The chromecast worked fine at my Mum's (on, ahem, TalkTalk) but refuses to work for me.  All other devices including Apple TV/airplay work ok.
Any ideas?
Thanks.
Paul
