Chromecast query
- Re: Chromecast query
Chromecast query
21-08-2015 11:31 AM
Recently purchased a chromecast and it works fine, however if left on all the time it gets fairly hot but if switched off it needs to be reset and the code re-entered.
The few websites I have visited seem to indicate there is no problem leaving it plugged in but if you own one what do you do ?
We are born into history and history is born into us.
3 REPLIES 3
21-08-2015 12:01 PM
I've left mine plugged in and powered up for weeks at a time with no issues.
21-08-2015 12:07 PM
I bought one in May last year and plugged it in to the TV in my bedroom when it arrived. This TV's either on or in standby and I've never had a single issue with it in all that time.
21-08-2015 2:41 PM
Thanks for the responses.
