Chrome...
petlew
Chrome...
Does anybody else have trouble opening Chrome?
I only use if for the specific purpose of building/editing my club website since it was opitimised by its server for Chrome and certain options are not available in Firefox.
But 5 or 6 times out of 10 it fails to open correctly and has to be closed using Task Manager. It is a fairly new installation with a number of security and anti this and that extensions, but has been giving this problem since it was installed a couple of weeks ago as a clean no extensions application. I've tried a re-install but it doesn't change.
I'm using Win 10 with the Creators update for this.
5 REPLIES 5
nozzer
Re: Chrome...
You should be on Version 58.0.3029.81 now. Last update was last week.
Are the web sites giving problems using Flash Player? Google abandoned plugins about a month ago so you now have to set it up specifically to "tolerate" Flash Player.
SpendLessTime
Fixes: 86
Re: Chrome...
Have a look at this thread "Chrome crashing after Windows 10 Creator's Update" at Google support https://productforums.google.com/forum/#!msg/chrome/9BVg6Wa6DEU/fRJ8uXhnAwAJ
petlew
Re: Chrome...
Thank you nozzer, I am on the latest version of Chrome. As far as I am aware Flash is not used by my website or by the server.
Unaccountably, in the remaining 4 or 5 attempts to open Chrome it works normally, which would probably indicate Flash is not to blame.
petlew
Re: Chrome...
And thanks to you as well Spend Less Time. There's quite a lot of info in there, I'll get back.
But, certainly seems I'm not alone.
Strat
Fixes: 565
Re: Chrome...
Moderator Note by Dick (Strat)
Topic moved to a more appropriate board.
