Chrome add-on Rain Alarm
ChrisL
Has anybody else had a problem with Rain Alarm?  I keep getting notified that it starts up automatically and runs in the background, even when my browser is closed.  It never does anything, and I don't want it.
How do I shut down or uninstall this useless app on a Windows 10 PC?  It doesn't appear in any of the usual lists of installed apps, and a search turns up no files. It's behaving like malware.
2 REPLIES 2
Jonpe
Fixes: 9
Re: Chrome add-on Rain Alarm
Found this here :
"The message comes from the old web app, NOT the extension and this is caused by Chrome slowly removing support for web-apps. I suggest you uninstall the web-app and instead use the Chrome extension. To uninstall the web app, enter the following into Chrome's address bar: "chrome://apps/" Right click on Rain Alarm und uninstall.
Posted by A Google User - 8 Jun"
Any help?
ChrisL
Many thanks, Jonpe!  I've never come across "chrome://apps/" before, and there it was Cheesy  Hopefully, having removed Rain Alarm from there, my problem has now gone away.
