Cherished domain name / spam
Brock23
I have been spammed and I get the 'Mail Delivery Failed: return to sender' message
I have several email addresses with my domain name   eg [email protected]  [email protected]. I set these up >15 years ago and have masses of contacts etc. However I have forgot the set up process
Only [email protected] has been affected. I suspect that [email protected] is now 'lost' to the spammer bless him. (though would appreciate any help here if not).
I have created a new mail box [email protected] to try and get around the problem. But my newly created address is [email protected] (the additional 'plus'). How do I get rid of the 'plus' bit ?
(I propose to run [email protected] and [email protected] in tandem until I close down mail)
Sorry if this is very basic - newbie /oldie
Tags (2)
9 REPLIES 9
Fixes: 578
Re: Cherished domain name / spam
@Brock23  if your domain is hosted by PlusNet, then [email protected] and [email protected] are the same mailbox.
Brock23
Thanks !
corringham
Seasoned Champion
Fixes: 23
As MisterW said, if the domain is hosted by Plusnet then the [email protected] and [email protected] are the same mailbox - BUT they are not the same domain. You can never move mydomain.plus.com away from Plusnet (and since Plusnet are deprecating e-mail at some point it will just go away, leaving you without your mail address). Your mydomain.com can be moved to another ISP/hosting company.
However, I'm curious as to what you mean when you say you have been "spammed". You suggest that the spammer has control of your mydomain.com e-mail.
If you are receiving mail delivery errors for mail you haven't sent, then it is much more likely that a spammer has simply been putting your domain as the "From:" address on mails they are sending from their own domain(s). It is straightforward to stop that by using SPF records to restrict which domains are accepted as being allowed to send mail from mydomain.com.
Brock23
Hi Corrinham - thanks for getting back
Yes Plusnet host my domain name.
I think your last paragraph nailed the issue. I started to get  lots of emails ('mail send failure) as described; that I did not send and each with a different email address. Hence my description 'spammed'
I have several other mail boxes with the same domain: 'cherisheddomain.com (family members etc) which seem to be unaffected.
I appreciate that I shall have to arrange for cherisheddomain.com to be hosted elsewhere in due course.
In the meantime, how do I go about the SPF route for the one (?) mail box that is affected ? (I would need simple instructions pls)
Are there any downsides ?
Likewise, are there any security implications (generally) as a result of this ?
RPMozley
Seasoned Pro
Fixes: 16
This type of spam is called “backscatter” and usually over time will eventually calm down.
It’s not associated with any direct attacks or malware, so any security concerns are not very likely.
That's RPM to you!!
corringham
Seasoned Champion
Fixes: 23
I'm afraid I don't use Plusnet's hosting, so I'm not sure of the process of adding an SPF record - I expect someone here will know. I expect @bobpullen  will know whether it is possible, and if so may be able to help.
Note also that although the "backscatter" will subside in time, it is worth using SPF (or other mechanisms to restrict the source of e-mails) as some e-mail systems may blacklist your domain as being a source of spam (it is bad practice, but some do this).
Browni
Aspiring Hero
Fixes: 61
@Brock23 as Plusnet host your domain this may help to set up the SPF record.
Fixes: 578
@Brock23 you can only add an spf record to the whole domain. The spf record will apply tom Sending mail from any of the mailboxes
@Browni thanks for that , I was trying to find a thread with the 'please -add-spf-records' example but  couldn't find it
Brock23
Thanks !
