Cheapish HP ink cartridges
Fixes: 133
I need to replace all 5 inks in my Photosmart C309g.
All the local shops including Maplin, Tesco, PCWorld, etc tend to be quite expensive so I was wondering if anyone can recommend a reputable online dealer.
Ebuyer seems reasonable.
Cheers.Thanks.
Forum Moderator and Customer
Fixes: 13
Re: Cheapish HP ink cartridges
Rubber Frog, in the channel islands.... is one I have dealt with before for HP replacement cartridges...
Choice Stationery is another.
However, I am a fickle buyer... and everytime I need a new cartridge, I scour the net for the cheapest with next day delivery for free  ! ! !...so the above may not be the cheapest available..
Be careful, cos some may look like a good deal, then charge you for delivery on top, and it may take a week to arrive .....  Wink Wink
Midnight_Caller
Why don't you get the HP ink cartridges refilled?
Try Cartridge World
I ordered mine through Amazon and they came from Jersey, £25 shipped 2 cartridges per pack @ £12.50 each  to make up the set of four so no tax  Lips are sealed
To do is to be - Neitzsche
To be is to do - Kant
do be do be do - Sinatra
Midnight_Caller
@Mav, You may want to have a look at Inks for Printers
Fixes: 133
Thanks for the replies.
@Midnight caller I never use compatibles or refills. I did try a compatible once from a reputable supplier and it messed up my Epson so never again.
@shutter I'd forgotten I had an account with Choice Stationery. They were cheap enough and I found a voucher worth 10% off so am getting 4 inks for well under £30 inc p&p which would have cost in the region of £35 + petrol.
Thanks again.
