Cheapish HP ink cartridges
- Re: Cheapish HP ink cartridges
25-07-2011 6:55 PM
All the local shops including Maplin, Tesco, PCWorld, etc tend to be quite expensive so I was wondering if anyone can recommend a reputable online dealer.
Ebuyer seems reasonable.
Cheers.Thanks.
Forum Moderator and Customer
25-07-2011 8:50 PM
Choice Stationery is another.
However, I am a fickle buyer... and everytime I need a new cartridge, I scour the net for the cheapest with next day delivery for free ! ! !...so the above may not be the cheapest available..
Be careful, cos some may look like a good deal, then charge you for delivery on top, and it may take a week to arrive .....
25-07-2011 9:52 PM
Try Cartridge World
25-07-2011 9:57 PM
To be is to do - Kant
do be do be do - Sinatra
25-07-2011 10:02 PM
26-07-2011 1:22 AM
@Midnight caller I never use compatibles or refills. I did try a compatible once from a reputable supplier and it messed up my Epson so never again.
@shutter I'd forgotten I had an account with Choice Stationery. They were cheap enough and I found a voucher worth 10% off so am getting 4 inks for well under £30 inc p&p which would have cost in the region of £35 + petrol.
Thanks again.
