Cheap Smartphone wanted
- Cheap Smartphone wanted
14-05-2015 1:48 PM
one that I can `play about with`.. to see how they work... and preferably one that i can use on any network, with payg....
Won`t be doing masses of texting... nor masses of anyt hing really... just the "odd" occasion to find something on the net... e.g. destination or directions when out and about...
won`t be making lots of phone calls either.... Still got a big balance left from my £10 top up last christmas.... !
So.. what should I look out for... good and bad points... when looking on ebay.... Talking about price... Dunno really ... I suppose up to £50
Your ideas and recomendations appreciated, guys....
Re: Cheap Smartphone wanted
14-05-2015 2:29 PM
then once you know what you want and what network you prefer buy a handset that meets those requirements, when you buy it make sure you get a screen protector and a case and then you will start off with a device that is already fitted with the software package your chosen network guarantees to work with them, sometimes the "unlocked" phones wont work or update properly due to network specific products that you don't have access to if your with another network.....
also if you find you start using your device more frequently for browsing and such you might find its cheaper to get a sim only contract with unlimited data than continue with topups on a payg basis.
end of the day I hope you find something that suits your needs
14-05-2015 2:42 PM
Just wondering... Is Win7.5 on a phone... 32 or 64bit..... I think Win 8 and 8.1 would be 64bit ..... correct ? (I have a prog that I would like to run which only works well on 32bit ).....
14-05-2015 2:53 PM
its rather basic but if it fits your needs then why not ?
as to 32/64 iirc all of them are 32 unless your looking at the upcoming lineup of premium handsets like the 15xx phablets
14-05-2015 3:03 PM
http://www.ebay.co.uk/itm/Microsoft-Lumia-435-Black-Simfree-Unlocked-Windows-Smartphone-New-Cheapest...
like you say... seems to do what I want....
and if I can run my 32 bit prog on it... so much the better.....
Looks like I`m getting updated pretty soon !!!
14-05-2015 4:10 PM
Although if you like the OS then you can always get a better featured version in the future, I know my kids like the 435's I got them as weekend away handsets much more so than the htc wildfire's they had for the last few years, although they don't like the poor camera on it.....still it beats risking damage to the premium grade 8x handsets that I couldn't afford to replace if they broke in the short term.....
14-05-2015 4:17 PM
14-05-2015 4:52 PM
Possibly won`t be able to run the prog I was thinking of... but hey ho... gotta start somewhere.. and certainly don`t get on well with Android on my tablet.. nor Linux when I play around with it... so having windows XXXX on it should make it a bit easier to get used to...
not too fussed about the camera...as I have a pretty good one I always carry around with me... ( Panasonic Lumix FZ72 with 60X zoom and 16 mpx )...
14-05-2015 5:28 PM
Its £45 if your an O2 customer.
It should be generic UK firmware & sim free / unlocked for any network.
Its also due to get Windows 10 update.
My mother got one last time it was on offer, its a decent first smart phone.
Also has a memory card slot so you can stick loads of music etc on it.
Check your sim card size whatever phone you end up with!
14-05-2015 7:35 PM
ah... hang on... parking.. and diesel... probably save about £3.00 ... ah well.... life gets tedious, don`t it... !
thanks for the info about Win 10 , and will check the sim card size... probably going to use... a PAYG one from these people
https://www.thepeoplesoperator.com/pay-as-you-go
14-05-2015 8:20 PM
I have had an Android smart phone in the past, never again!
Ive also tried the I Phone, its just not for me either - I couldn't downgrade to an I Phone now
Speaking of Windows 10 for phones, the latest technical preview build has been released tonight
Microsoft have been rolling out the updates & bug fixes to this really quickly
14-05-2015 8:59 PM
No Bluetooth IIRC but it is 3G and not 4G.
15-05-2015 10:28 AM
I still have an old Motorola in my cupboard. This flip phone runs on a version of Linux and must be a Granddaddy of modern smart phones.
It's still a very pleasant and nice to use WiFi enabled phone.
And the battery lasts several days.
15-05-2015 10:31 AM
@shutter good luck running any desktop app on your new phone.
15-05-2015 10:35 AM
