Changing password tool
ajax
In the Username & Password Security Guide (in the Support Library) there is – under the Broadband Access heading ‘How do I change the password?' – the instruction: ‘Change your password using the ‘Change Password tool’.
Clicking on the ‘Change Password tool’ link merely takes me to the standard Plusnet login page. Where is the tool for making a change?
2 REPLIES 2
SpendLessTime
Fixes: 86
Re: Changing password tool
https://portal.plus.net/my.html?action=mydetails&?membermenu=accountdetails
You have to login to see the options under the account details menu.
ajax
Got it. Many thanks. Smiley
